AVM vs Aisin Hubs
brakes-shocks-lockers-etc
Heath
AVM vs Aisin Hubs
Post by Heath »
So what are the pros and cons with each? Looking for some for my zuk (vitara) and have to decide which flavour to go with before jumping next week.
So far I know I need the cone washers for the Aisin ones but not the AVM ones and maybe the AVM ones will just bolt in without modification.
Heath
tgaguy1
Re: AVM vs Aisin Hubs
Post by tgaguy1 »
AVM hibs are alot weaker than Aisin hubs. One opinion is that by running a weaker hub, it becomes the "fuse" in the front drive system. It is alot easier to replace a FWH out on the track than a CV.
oldblue
Post by oldblue »
I made a special CSK drill 5degrees I think to drill out the stud holes on AVM and supperwinch hubs so we can fit collits to them, stops the stud/nuts from slackening off.
Heath
Post by Heath »
oldblue wrote:I made a special CSK drill 5degrees I think to drill out the stud holes on AVM and supperwinch hubs so we can fit collits to them, stops the stud/nuts from slackening off.
Going to use allen bolts (or whatever they are called) and a little loctite so not worried about the cone washers. In fact saves me buying some at a dollar a pop.
I didnt think of the "fuse" being the hub, but at $60 dollars a pop they might be too expensive to do that.
Basically I can get both types at the same price, one needs cone washers the other doesnt. One needs some mods to fit, the other I am not so sure but was told they just bolt on.
I have several spare axles and CV's and a few front diffs too so (touch wood) breakages arent too much of a problem.
suzookyman
Post by suzookyman »
Heath,
i put in the AVMs a while back, all good so far.
keep collecting those diffs mate ya gonna need em!
Al
haynzy
Post by haynzy »
I blew my avm ones to bits no probs with the aisen ones though
Bulletproof
Post by Bulletproof »
oldblue is right, unless you use collets you will have trouble. I have seen lots of people use allen bolts and loctite and they shear or come loose. There is no choice as far as I am concerned with hubs.
Only Aisin and you will never have trouble.
Cheers Richard
Never say die, up man and try
Heath
Post by Heath »
I have decided to go with the aisin hubs.
cheers all for your assistance guys.
Heath
PuddleJumper
Post by PuddleJumper »
Good choice Heath... They're the best ones! :D
wjw
Post by wjw »
Cheers Richard
Without the collets you get minute movement which over time works the bolts loose and slogs out the holes... thats what happened to mine :-(
Who knew Prados could fly?
