then jacked it up on jackstands pulled the gearbox out which was a mission in itself just didnt wana come out so i have a bit of a wresle with it and finally it came out no need for a jack to get it down with just brute force cus its so light for a gearbox, gota love the zukes. thentryed the release bearing it was a bit stuborn not sure if is should do this but it needed a jiggle about to get it to go in and out it needed presure on it to get it back in anyways heres a pic
then took the clutch out had alot of mud in it which id say could have been make the clutch do what it did.
then cleaned the gbox all up
in the process i found the front d shaft flange bolt was loose really loose and i had been getting alot of vibration when in 4wd last run.
hope someone can help
martin
