wheel bearings? (safari)
JR
Post by JR »
hay all, am new to this site, singed up a few weeks ago. im after a bit of advise on the front end. returned from a trip to the west coast to find a lot of slop in the front wheel bearings, tightened them up sweet as but driving along, all of a sudden it will bind up, pull to the side, make a lot of noise, then let go and go back to normal. Any thoughts on what this could be if not the bearings? and if so are these easy enough to do myself?
rough 'n' ready
albundy
Rolly Polly
Re: wheel bearings? (safari)
Post by albundy »
Pull it apart and have a look, it aint too hard. I would say the bearing is stuffed, it won't hurt to pull the whole hub apart and grease everything.
Al
yes rebuild before driving again , wheel bearing breaking while driving will destory the whole hub, the cost high,
JR
Post by JR »
cheers for that guys, will get some orded in tomorow, was told by the guy at seaco bearings that they would have to be pressed back on? this not the case ay?
rough 'n' ready
PR
In the crap again
Post by PR »
JR wrote:cheers for that guys, will get some orded in tomorow, was told by the guy at seaco bearings that they would have to be pressed back on? this not the case ay?
I did mine the other day all you need is a hammer and a long punch :wink:
(021) 02388443
albundy
Rolly Polly
Post by albundy »
Yeah I was down the workshop yesterdasy hearing about your hub rebuild, don't forget to pull the CV apart and pack with grease, hey PR :oops:
Al
PR
In the crap again
Post by PR »
I did just not good enough :oops:
(021) 02388443
Return to “Tool Shed”
