whats a manual box worth?
mudjunkie
Post by mudjunkie »
i picked up a donor vehicle for my "mud junkie", i run an auto box, this has manual gearbox which in excellent condition, but has buggered 2.5ltr turbo,
was going to pullout motor and box, if anyone keen, what sort of pricing think worth?
"MudJunkie" active member of the Geyserland 4wd Club
92' 3.0 v6 swb
40mm bodylift, 60mm suspension lift + factory 50mm hydralic lift, 33" BFG's, LSD, 8000LB Winch, Balljoint Flip & Extn, Bushranger 72ltr Comp & tank, many more mods
WACKO
Pyro
Re: whats a manual box worth?
Post by WACKO »
ive seen them advertised on trade me for $250, but ive never seen one sell.i used a diesel transfur in mine and gave away the box. the transfur can be used on both petrol and man, but the box can only go on a diesel if it came off a diesel as the input shaft is differant. no box parts interchange with autos. you may have more luck selling the stuff as a manual conversion. pedal box and all. think thats in the region of a few hundy.
Sam
nivaman
Post by nivaman »
What ratios are the petrol and diesel v5mt1 gearboxes?, i have what i assume to be a L300 column shift box Image Image and can get a v5mt1 diesel box, can i use the column shift box with the diesel transfer case and still have the t/case lever and gear lever in the normal place?.
meece4x4
Post by meece4x4 »
mudjunkie wrote:i picked up a donor vehicle for my "mud junkie", i run an auto box, this has manual gearbox which in excellent condition, but has buggered 2.5ltr turbo,
other than the shagged turbo any idea what the rest of the motor is like?, might be keen on grabing a spare block and head for my sh%tbox
NJV6
Post by NJV6 »
I think the photos are a KM145 box.
Definately not a V5MT1 box or a V5M31. I will take some photo's of one (a V5MT1) today for you. It could also be a V5M21 but can't tell you what they look like.
That is not a super select transfer case either.
They are all Hydraulic behind the V6 but I cannot help with gear ratios.
nivaman
Post by nivaman »
Photos would be good njv6 cheers :)
nivaman
Post by nivaman »
How those photos looking njv6?.
NJV6
Post by NJV6 »
Ah yes. OOPS.
Tomorrow.......
nivaman
Post by nivaman »
No piccies?, :? :wink:
NJV6
Post by NJV6 »
Ah yes, the other tomorrow!
This is a V5MT1 box from a 3.0 V6 with the Super Select full time 4WD transfer case behind it.
nivaman
Post by nivaman »
Cheers muchly :D .
I can safely say now that i do not have the v5mt gearbox in my garage but what i assume to be a fm145/6 gearbox, i would also assume the ratios are similar?, i know they are close to a Lada five speed box and somewhat close to a Fiat 131 five speed if what i read is anything to go by.
Can the low box ratio be changed, 1.9/1 to something a bit lower?. I wonder if the super select t/case will fit behind the fm145 t/case?.
Chears again njv6 :D :D .
Return to “Mitsubishi”
