4.2 TD42 diesel motor. 275498 kms.
5 speed manual.
LSD rear.
New wof (Expires 26-8-09). Registered until June 09. Rucs to 276532 kms.
4" suspension lift.
2" body lift.
33x12.5x15 Goodyear wrangler Mud Terrains, with heavy duty tubes, on alloys, done 6000 kms.
Sunroof.
Rear spotlight.
Bright rear interior light.
Rear lighter plug with heavy wiring and permanent power.
Snorkel.
Globe type headlights.
Stereo cassette player with 4 speakers.
Carpet dash mat.
Onboard air, consisting of; Outback devil compressor (72 litres per minute) bolted behind drivers seat, feeding into a 16 litre tank bolted behind passengers seat, running a pressure cutoff switch. (Cuts in at 85 psi & cuts out at 110 psi).
Rear air hose coupling.
Full size truck air horn under bonnet with air over electric solenoid.
Solid front boiler tube bumper, with bullbar & bull horns.
CB aerial on bullbar, with coax cable and power on dash (Power for 2 radios).
12000 lb, 24 volt electric winch running 28 metres 11mm steel cable & hook. (Less than a year old).
2 10000 lb recovery hooks on front.
40000 lb recovery hook on rear.
New pressure plate, clutch plate and release bearing fitted this weekend (14th/15th Feb, receipt available).
Drag link reconditioned.
New front control arm bushes.
Reconditioned alternator mid last year.
New disc pads all 4 corners last year.
New handbrake shoes last year.
New gear lever nylon bush last year.
New clutch slave cylinder.
New clutch master cylinder.
Good 2nd hand clutch master cylinder power booster.
Brake Master cylinder kitted.
Recent 2nd hand wiper motor.
Heavy duty tube rock sliders both sides.
Rear quarter panels cut and properly folded, with heavy bars underneath.
Spade mount on bonnet.
Hilift jack mount in rear.
False floor in back.
Alloy bash plate under front.
Radiator recored last year.
Twin electric fans.
Fire extinguisher.
A few dents here & there as is to be expected with a club truck, but no rust.
Will come with good spare bonnet.
Both rear doors, (1 missing glass).
Removable towbar and trailer plug (24v).
Rear seat and seat belts.
Original carpets.
Spare sets of disc pads.
1 spare new engine mount.
Spare set front indicator lights.
Truck does not use oil or water.
Reliable starter & runner.
A very capable club truck.
$6500.00
PM me on here for further contact details.
http://www.trademe.co.nz/Browse/Listing ... =202017735
