hosehustler wrote:haydgq wrote:Hey there guys, What is the difference between turbo and non-turbo Toyo Mr2 calipers.? Is it the handbrake setup the reason why the non-turbo mr2 rear calipers are the ones to get.?
Cheers Hayden.
The only difference is the width of the calliper, the non turbo ones are the correct width to match the pado rotor, from memory the turbo ones are about 4-6mm wider( as they have wider discs) so if you use them when the pads are half worn theyll fall out
Cheers for that Tim, And we dont want our pads falling haha. Do you know when you might be able to sell a set of the spacer/adapter plates to mount the calipers.?? Me and Haynzy both need them and live in the same town eh.
Thanks Hayden.
