Solid front axle surf???
you manus
Post by you manus »
I am looking at swapping out the IFS on my surf for a beam axle from a hilux was just wanting to know how hard, what it reqiures, and anything else that may help before i dive in and get into the shit
90' 2.8 Hilux Surf
0272543646
Andrew1706
Re: Solid front axle surf???
Post by Andrew1706 »
http://www.trail-gear.com/sas.html
There is plenty of off the shelf kits that require a bit of technical knowhow and welding skills.
There are cheaper alternatives though, check out some of the build threads on here - I believe HoseHustler has a thread documenting his coil spring solid axle swap.
Jafa
Post by Jafa »
Or for the same kits with NZ prices... :lol:
http://www.snr4x4.co.nz/eliminator-kits ... _39_1.html
021 273 9942
jafa@inspire.net.nz
Andrew1706
Oooops, forgot about you fullas :oops: :lol:
J_Dub
Post by J_Dub »
plenty a guys on here that can do it with there eyes closed, done and dusted over a long weekend, leaf sprung conversion
Engineer
Post by Engineer »
its easy now that ive done it. id do it again. i used a bundera/lj70 landcruiser front end
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
you manus
Post by you manus »
id better start saving then, the kit cost as much as the truck did
90' 2.8 Hilux Surf
0272543646
radar21
Post by radar21 »
im gona do mine once back in chch but im just gona do budget build leaf set up and then im planning on commy v6 engine swap
scott gibson
MATT4U
Post by MATT4U »
i have an axle I want to sell......
radar21
Post by radar21 »
i could be keen
scott gibson
arbhilux
Post by arbhilux »
I have got a 2001 sr5 hilux that im just about got all the solid front in getting a diff for it 2moro it wasnt to hard i got the sump cut so it could get as much travel as it can. its not as nice to drive on the the road but at the end off the day its way better. its cost me so far just under 3500 to swap, i got the kit off SNR4X4 and i wouldnt go any wear alse there helpful and now there stuff at the end of the day.( Also if you have 2 get a 3.7 hilux diff to macth the back its like trying to find gold getting 1 shity late model crap)
GotFlex
Post by GotFlex »
do you need a 3.7 diff head?? i mite be able to get you one
arbhilux
Post by arbhilux »
how much you wont for it, and what model it came out of
GotFlex
Post by GotFlex »
price im unsure of, 2006 i think hilux, id have to check
Return to “Toyota”
