Do I just replace with standard mounts and put in some sort of retaining strap or is there a better solution. Seems to be a common problem but couldn't find any posts on it.
Cheers Murray
Muzza wrote:My engine mounts broke on the weekend. " What a stupid design not having some sort of retaining strap. "![]()
Cheers Murray
Swamped wrote:Had to replace one the other day too. but it was drivers sideI shouldn't think your motor should be overrunning like that either FB. Unsure if theres an alternative to the nissan ones...It was like a hundy bucks for the part though.
Swamped wrote:Apparently they don't have the flashest fuel cutoff system to shut them down so they rumble real bad but its only for a short time. Least that was what i was told.
Swamped wrote:tony at speedy lube might still have mine from the other day.
Haynzy wrote
"Just use some toyota parts
Good weekend though "
flyingbrick wrote:Swamped wrote:tony at speedy lube might still have mine from the other day.
thanks
Any chance you could try track them down? I'll throw a 6 pack of your favorite beverage your way.
