3.8 V.6 what gearbox to use
For all topics relating to Petrol engines and modificiations.
hellzuki
Post by hellzuki »
hey all, ive got a commdore VN v6 for my suzuki ecudo and i am just wanting to know what the best gearbox transfer case to use? i was considering an auto from a hilux surf. any help would be great, cheers
Steve_t647
Re: 3.8 V.6 what gearbox to use
Post by Steve_t647 »
Most keep the Commodore auto and adapt it to the toyota transfer cases, change the output shaft and an adapter there was a writeup on here by Chopper that went through what needed to be done (I can't find the thread it is here somewhere).
The Commodore automatic is actualy shorter than the Toyota so his dual transfer cases ment almost no change to his drive line.
Edit because I foobared as quoted below :oops:
Dace
Post by Dace »
Steve_t647 wrote:Most keep the Hilux auto and adapt it to the toyota transfer cases, change the output shaft and an adapter there was a writeup on here by Chopper that went through what needed to be done (I can't find the thread it is here somewhere).
The commodore automatic is actualy shorter than the Toyota so his dual transfer cases ment almost no change to his drive line.
Am guessing ya mean keep the Commie auto and heres id the link to choppers "how to" thread
viewtopic.php?f=30&t=13146&p=147711&hilit=holden+v6+v6#p147711
hellzuki
Post by hellzuki »
is there a cheaper option? that adapter is $1250. cheers
timotheus
Post by timotheus »
Use a divorced transfer case. Datsun 720 works. So do some landcruiser ones.
Some where a fella had a bulid with a land crab box with PTO monted midship in a Jimmy.
Looked like a great setup.
hellzuki
Post by hellzuki »
a divorced transfer case?
nivaman
Post by nivaman »
hellzuki wrote:a divorced transfer case?
A lada has one, Image
timotheus
Post by timotheus »
A divorced transfercase is a stand alone tcase. One that is not already attached to or part of the gearbox. They are attached via a small (normally) shaft. They have their own oil supply and are easy to work with.
The most commonly used is the Datsun 720.
Bubba
Post by Bubba »
A divorced transfer case is a broken transfer caser that has been put under to much stress from the whining gearbox it was coupled to. You can spot it fairly easily as it's internal workings have been smashed to bits. You can also smell a bitter bile type bile from it as well.
You will have to check which way it is coupled to. The difference between a female and male divorced transfer case are fairly easy to spot. The female comes attached to the whole truck and the male is normally discarded until it can be refurbished and attached to a decent truck
Benjamin Franklin
THATS GOLD
you rock bubba
Windsurfer0206
Post by Windsurfer0206 »
probably a stupid question but can you use the standard hilux/surf box with diferent bellhousing?
Steve_t647
Windsurfer0206 wrote:probably a stupid question but can you use the standard hilux/surf box with diferent bellhousing?
You can the cost of keepin the manual is Higher as the clutch usualy goes larger and the bell housing replaced or modified, there are a couple of places that do this, keeping the manual with the 3.8 you also have to be careful of your diffs the auto takes the savageness out of the 3.8 the manual does not.
The price difference is not a lot and depending on driving style know people with both auto and manual and they drive the way the 4wd will survive, me personaly I like the manual for certainty downhill but in all the river work done down here I see the benefits of the auto.
tintin
Post by tintin »
where would you find a bellhousing for a manual setup, who makes them?
1980 4x4 Hilux Restoration Image
Steve_t647
tintin
Post by tintin »
Steve_t647 wrote:http://www.v6conversions.com.au/TOYOTA.HTM
http://www.marks4wd.com/
http://www.rodshop.com.au/toyota/hilux.htm (they have an adaptor plate)
NJV6
Post by NJV6 »
Easy as to make your own adapter for these to go onto the toy gear driven transfer case if you have access to a lathe.
tintin
Post by tintin »
NJV6 wrote:Easy as to make your own adapter for these to go onto the toy gear driven transfer case if you have access to a lathe.
if i was to do this conversion i would have to buy the stuff to do it, unless someone was aready setup package
Flash2004
Post by Flash2004 »
Something to consider when selecting an auto is the control it offers on descents, especially in reverse. The best time to lose it and roll is going backwards fast downhill with the brakes locking the front wheels.
A ZF HP22 4 speed (Disco/Rangie) engine brakes from idle when locked in first, enough to descend a cliff but goes a little quicker in reverse. Also gives lightning manual shifts either up or down and in only my opinion is one of the best off road autos there is. Not suggesting you use one, just suggesting this engine braking ability should be well up your wish list for capability and safety. Some just don't have it or not enough of it. cheers
