Canty trip- 21st feb :)
- nickcampbell
Gidday all, im back, rescently had engines problems burntout 2 engines due to over heating
on my 3rd and looks like its fixed this time. Im keen to do something this comnig saturday, anything will be cool for me, apart from waimak. Any ideas? Is worsleys still up there? or have the removed it compeltely now? last i saw they had graded aorund last 200-300m of it.
1995 71series cruiser, 33" Maxxis Buckshot, front + rear lockrite, 50mm body lift
Re: Canty trip- 21st feb :)
went through just before christmas and it was all good, have been meaning to go up for another look so count me in if you end up going, just a pitty they ruined the last part, never got to drive it and it was ment to be the best bit
rough 'n' ready
Hi Nick...I had a minor overheaing problem the other week & have come up with a cunning plan to get a bit more cooling using my AirCon fan.
When you turn on your AC current goes to a the AC pump & pulls in the clutches & makes the pump pump....it also automatically turns on the electric fan.
Im going to to insert a switch before the AC pump so i can disconnect the AC pump when needed so when i turn on the AC all that happens is the fan goes on giving me more cooling....not done it yet but tested it last week & seems to go good.
- nickcampbell
yeah the best part was the part the council ahve removed, but its still enjoyable drive up worsleys... im keen to head up there on sat if no one else mentions or shows any intrest in any other places. Well my truck doesnt have electric fans lol all my fans run off pressure. it has some special name haha but yeah, the main fan wasnt spinning when it needed to be... so that was 1 cause of it, but also had cr*p in the radiator, and the factory clamps had given up abit of tension so also my radiator was leaking once it heated up alittle. Also my temp gauge is useless, doesnt pick up my engine is over heating till its over heated. But i can tell way before it by my leg, as i have no carpet my transmission gets extremely hot, and burns my leg haha, owell im keen for worsleys if nothing else comes up
nickcampbell wrote:yeah the best part was the part the council ahve removed, but its still enjoyable drive up worsleys... im keen to head up there on sat if no one else mentions or shows any intrest in any other places. Well my truck doesnt have electric fans lol all my fans run off pressure. it has some special name haha but yeah, the main fan wasnt spinning when it needed to be... so that was 1 cause of it, but also had cr*p in the radiator, and the factory clamps had given up abit of tension so also my radiator was leaking once it heated up alittle. Also my temp gauge is useless, doesnt pick up my engine is over heating till its over heated. But i can tell way before it by my leg, as i have no carpet my transmission gets extremely hot, and burns my leg haha, owell im keen for worsleys if nothing else comes up
I think you might mean a viscious fan
- nickcampbell
Yeah thats the word i was looking for haha
JR wrote:went through just before christmas and it was all good, have been meaning to go up for another look so count me in if you end up going, just a pitty they ruined the last part, never got to drive it and it was ment to be the best bit
I'll be keen if I can get some tractor valves by then and also weld up standard valve holes. Try to get it done for the weekend. I think I'll let you lead next time, and you can have a swim with your truck.
GU patrol 35s ect.
Mud Hog wrote: but no rivers!!!
Dosn't your nissan float
(021) 02388443
(021) 02388443
Dose'nt quiet float, I'll take the dinghy next time. Thanks for your help PR Auto has sorted it self out
, Electrics don't like being submerged, oil has stopped pouring out too
PR wrote:Mud Hog wrote: but no rivers!!!
Dosn't your nissan float![]()
GU patrol 35s ect.
- nickcampbell
sweet asss gues we off to the old worsleys
on saturday then... what time suites you guys? i can go anytime
Mud Hog wrote:JR wrote:went through just before christmas and it was all good, have been meaning to go up for another look so count me in if you end up going, just a pitty they ruined the last part, never got to drive it and it was ment to be the best bit
I'll be keen if I can get some tractor valves by then and also weld up standard valve holes. Try to get it done for the weekend. I think I'll let you lead next time, and you can have a swim with your truck.Keen on Worsleys but no rivers!!!
rough 'n' ready
I could be keen depending on what time it is after 5pm would suit me as I cant get off till then
but its up to the rest of you guys
(021) 02388443
(021) 02388443
never done that track will a pretty much standard cruiser make it up?
depends on how much damage you will put up with
scott gibson
im keen for after 5, should be fine in your cruza, depends on the rain realy, iv seen it pretty slipry. sure a nissan will pull you up
rough 'n' ready
what sorta damage are we talking about here i could be keen too
- nickcampbell
damage?? ive been up worselys like 99999999999999 times i have never ever see nany panel damage.... only broken difs and afew over heated engines.... if anything you mite break off a wheel flap/skirt or if your really low you mite put a little ding in a bumper or break a tail light.... if your lucky, like ive said ive never seen anyone damage a truck gonig up there
- nickcampbell
PR wrote:I could be keen depending on what time it is after 5pm would suit me as I cant get off till thenbut its up to the rest of you guys
We can set it for 5:30 PR, Saturday, 21st feb?? so you can attend PR, and we should be finished and home for dinner if all goes well. All happey with that?
I should be right
(021) 02388443
(021) 02388443
nickcampbell wrote:damage?? ive been up worselys like 99999999999999 times i have never ever see nany panel damage.... only broken difs and afew over heated engines.... if anything you mite break off a wheel flap/skirt or if your really low you mite put a little ding in a bumper or break a tail light.... if your lucky, like ive said ive never seen anyone damage a truck gonig up there
Sounds like a boring trip then, you should come up with us Last time i was up there Jafa flopped his truck twice
^^^^ What he said!
I am just going up to test the truck out after rebuilding both axles and the whole brake system so I know it will be ready for easter
(021) 02388443
(021) 02388443
PR wrote:I am just going up to test the truck out after rebuilding both axles and the whole break system so I know it will be ready for easter
I think you meant brake.................... but then it is a Nissan
Wot you talking about
(021) 02388443
(021) 02388443
- rangimotors
For those of you who haven't been up before, after this rain i would reccomend that mud tyres and hooks would be a bare minimum. The trip should be ok just make sure you don't get to far our of your league, plenty of well setup experianced guys have done damage and rolled etc up there. Just go as far as you feel comfortable and you'll be fine and don't fall into the trap of following someone who is better set up than you are and expecting to drive the same lines, or having someone with a big truck but bugger all experiance tell you what you(or your truck) can and can't do after all its your life and you that pays the damage bills.
I find it hard to beleive you have been up there that many times and don't see it fear to be advertising your huge level of experiance to make others trust you and come on your trip when your also pretty new to the game..
As per your sig, do you really have a 140mm body lift??
and dont be afraid to ask for help. i did some panel damage when i went up but i was in the suzuki witch liked lieing on its side but some of the others did some minor panel damage in the bigger trucks to but with out asking for help i probly wouldent of made it up its lot of fun as long as you take your time and think about ever move you are about to make
scott gibson
- Steve_t647
With todays and tomorows rain it will not be an easy trip and you will struggle for grip, in wet conditions falling into ruts can cause panel damage, break bead's on tyres giving you a flat. I have done it in the dry it wasn't too bad but you do have to be careful in the wet.
If you don't have a couple of well setup truck's with good recovery gear it could take a while to get unstuck and back down, take a shovel
Hi to all wishing to participate on this trip up Worsleys. I am now wearing my southern zone PRO; Kiwi4X4 hat and ask that because of the recent rain that you take care of yourselves and care of the Track, the track is very fragile after rain and is not very forgiving on vehicles, there are two NZPO cables and two alkathene hoses that have become unearthed in places please be weary of these and keep off them where possible. I went up to the top yesterday and there has been track maintenance done in places, the 100mts before the bowl area has had the ruts filled in and the 100mts before the iron gate posts and to the top of the hill have been graded , 2WD. Take care and keep safe, after my trip up my advice is , If it keeps raining don't go because you will get damage, I sustain irreparable damage in the dry
I BLEW A STRAP ON ONE OF MY JANDLES AND THE DOG HURT IT'S PAW, we both came down limping,
FITZY.
FITZY.
FITZY.[/quote]
GU patrol 35s ect.
I am going to leave it for a couple of weeks as I want to test not break the truck
and also I dont know if I have met some of you guys and I dont know what your experence or truck setups are like so lets play it safe there's always another day
(021) 02388443
(021) 02388443
