I'd like to space my front diff forwards- I'll make the spacers myself.
I'll be doing this in preparation for larger tyres.
Opinions advice and dimensions for the spacers would be much appreciated.
-Nathan
flyingbrick wrote:Hi all.
Opinions advice and dimensions for the spacers would be much appreciated.![]()
-Nathan
flyingbrick wrote:I read on another forum last night that the max thickness possible is 12mm as otherwise you end up not being able to get the nut onto enough thread![]()
I'm wanting to run 35 x 12.5's on either an 8 or 10" rim. Have not decided yet. I want to run a total of 85mm of lift and will cut guards as necessary- Hopefully then i'll have an excuse to cut the rust out of the rear of me front guards from where the mudflaps were. so when people ask why ive cut my guards i can say "to make my big tyres fit" rather than "to remove the rust"![]()
I figure its not possible to have too much clearance so will do the spacers. I'm not buying them- I'll machine them up myself.
Can anyone tell me what diameter the threaded portion of radius arm is? is there a shank under there which is larger? I don't want to take the arm off and put it all back together (so i can get to work) just for a measurement.
And does anyone in the waikato have a spare radius arm washer sitting around?
-Nathan
flyingbrick wrote:Thanks all
Has anyone here bent the washers out of shape and popped a bush out?
If its a real problem I'll go to the trouble of making it once piece -spacer and front washer together.
-Nathan
-Nathan
curly12 wrote:flyingbrick wrote:Thanks all
-Nathan
Can't be assed taking photos so will call in on Thursday and you can measure them for yourself
flyingbrick wrote:curly12 wrote:flyingbrick wrote:Thanks all
-Nathan
lol, ffs, the only thing i want is the ID of the spacer. hahaha. gotta take them off for that![]()
albundy wrote:I ran aset of 35 creepy one weekend and they rubbed like shit. I spaced my front diff forward 15mm with radiu arm spacers and new 3" suspension. Running 35 silverstones, no rubbing on body.
flyingbrick wrote:I got drop boxes comingKills two birds with one stone.
So how far forwards can you move the diff before you run out of driveshaft extension? the only serious thing stopping you fro going more than 15mm forwards is the panhard, correct?
-Nathan
flyingbrick wrote:I have caster correction bushes coming too- so have some options![]()
I'm only wanting to go 3" lift so guess i can go without
