is it electric or cable?
If electric- Do the Jaycar speedo correction modules work??
speedo driven
- flyingbrick
speedo driven
Re: speedo driven
electric,
all i done was took the speedo needle off and moved it round instead of starting at zero mine starts at 8km which is how much mine is out at stand still,its bang on with my gps aswell,'
vince
vince
- flyingbrick
Re: speedo driven
Thanks.
Got a bit worried as i just did a search on pootroll4x4.comb and i saw some evidence that it was cable driven.
Ive bought one of these units and figured i could take it back if it was cable driven
http://jaycar.co.nz/productView.asp?ID= ... rm=KEYWORD
Will give it a go.
Will give it a go.
Safari Swb
Re: speedo driven
is the odomotor a seperate wire to the speedo??
Re: speedo driven
yep it sure is
vince
vince
- flyingbrick
Re: speedo driven
For future reference: i just found this document.
Appears to be how to use the jaycar speedo correction unit with the nissan patrol.
http://drop.io/patrolspeedodoc
I love it when shits this easy.
- flyingbrick
Re: speedo driven
the MK2 unit (current version that i have) says on teh front that its now compatable with nissan vehicles
so does not require all that modification.
Re: speedo driven
in the patrol speedos their is a little potentiometer (big word i know, means adjustable thingy) that you can adjust to calibrate your speedo .you need to pull the front clear cover off your speedo cluster and on the top of the circuit board above the speedo you will see it .i drilled a 6mm hole directly above it so i could adjust it with a small screwdriver while driving .then just borrow a gps ,drive down the road and turn the adjuster till it reads the same as the gps .simple a
- flyingbrick
Re: speedo driven
you are kidding.
good thing i hadn't opened the box yet.
Re: speedo driven
Hi,
Anyone know if it is that easy for the 80 Seriers Landcruiser. Has anyone used the Jaycar Kit for 80 series.
Thanks
Tim
Thanks
Tim
Re: speedo driven
sig wrote:in the patrol speedos their is a little potentiometer (big word i know, means adjustable thingy) that you can adjust to calibrate your speedo .you need to pull the front clear cover off your speedo cluster and on the top of the circuit board above the speedo you will see it .i drilled a 6mm hole directly above it so i could adjust it with a small screwdriver while driving .then just borrow a gps ,drive down the road and turn the adjuster till it reads the same as the gps .simple a![]()
Nice !
Thanks for that Sig
- flyingbrick
Re: speedo driven
suzolla wrote:Hi,
Thanks
Tim
If its electronic speedo im dead sure it'll work
I'm building my kit up anyway. its a nice project
where in the country are ya?
