No factory BOV
Skitts
No factory BOV
Post by Skitts »
why dnt diesels have B O Vs and can u put one one them
Re: No factory BOV
What the hell is B O V
red-devil
Re: No factory BOV
Post by red-devil »
BOV = blow off valve
becouse we dont need the noise of a wssshooo when we drive.
Re: No factory BOV
psssshhh psssshhh psssshhh
if ya do it, make it real loud to piss off the neighbours and hey while you're at it, why not put a screamer pipe on it too
Jezza
Re: No factory BOV
Post by Jezza »
why would you want a blow off valve?
Isuzu Mu 3.1TD
Skitts
Re: No factory BOV
Post by Skitts »
cheers to al u smart asses.... bovs arnt just to make noise just wnted to no why diesels dnt have them do they need the presser for power unlike petrol cars need to relese sum of the presser??
Jezza
Re: No factory BOV
Post by Jezza »
Diesels don't have a throttle butterfly valve so there is no need for one
Isuzu Mu 3.1TD
Skitts
Re: No factory BOV
Post by Skitts »
sweet cheers
tweake
Re: No factory BOV
Post by tweake »
some diesels have a butterfly (used for emmsions purposes) and a BOV can help on those. however generlly its easier just to get rid of the butterfly.
Re: No factory BOV
not smart ass boy, just a need to learn
darinz
Re: No factory BOV
Post by darinz »
I contemplated a BOV on mine as it the turbo would stall when I went from WOT to nothing during comps. I never did but it was thought about. It is a case of in a worked deseil there 'may' be a place for them to protect the turbo but I would imagine it is a waste of time for most.
KiwiBacon
Re: No factory BOV
Post by KiwiBacon »
darinz wrote:I contemplated a BOV on mine as it the turbo would stall when I went from WOT to nothing during comps. I never did but it was thought about. It is a case of in a worked deseil there 'may' be a place for them to protect the turbo but I would imagine it is a waste of time for most.
You'd also need a real control system for it. Something that monitored pedal position and boost. Apparently there is something available for the duramax along these lines.
Unfortunately almost all the BOV's for sale in the aftermarket are solely to make noise. Some even boast about being the loudest.
Not good for the engine either, watch your average clown ricer and the cloud of black unburnt fuel that gets dumped out the exhaust when the BOV vents. Engines which have an airflow meter (instead of a MAP sensor) think all that dumped air is still going through the engine.
The factory systems dump it back into the intake (behind the AFM) so it does still go through the engine.
tweake
Re: No factory BOV
Post by tweake »
the few guys i know of that do run BOV's have it rigged via idle switch and clutch switch. with moderatly worked motors, lead feat and constant gearchanging apparantly it helps keeps the turbo rpm up.
i suspect if you drive it more like a truck rather than a sports car then the effect is proberly minimal.
Re: No factory BOV
Stick one of these on them
http://www.trademe.co.nz/Trade-Me-Motor ... 152290.htm
:D :D :D :D :D :D :D :D :D :D
Jezza
Re: No factory BOV
Post by Jezza »
I've always wanted a blow off valve so I could do this :D
Isuzu Mu 3.1TD
tweake
Re: No factory BOV
Post by tweake »
Jezza wrote:I've always wanted a blow off valve so I could do this :D
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
duck shooting season is not far away, i wonder if i could fit one in time :D
sig
Jeep Jeep
Re: No factory BOV
Post by sig »
thats is quite funny :lol: :lol: :lol:
long
Re: No factory BOV
Post by long »
Now that would be a real laugh would it not
darinz
Re: No factory BOV
Post by darinz »
tweake wrote:the few guys i know of that do run BOV's have it rigged via idle switch and clutch switch. with moderatly worked motors, lead feat and constant gearchanging apparantly it helps keeps the turbo rpm up.
But when you have a worked TD42 it behaves like a sports car so you have to drive it that way! :mrgreen:
But seriously, in comps when you go from full boost and high revs to full stop in about 1 metre you do need something. Not good for the motor (or driver!) but that is racing. Good ideas about using the idle switch etc.
