vg30 v6
Re: vg30 v6
I could be wrong here but for a vg30 i would be looking at an auto out of a 300zx i heard they were pretty strong
Re: vg30 v6
an auto out of a V6 terrano???.......
Re: vg30 v6
terraro trans out the wrong side for i am going to be doing. The thought was to use a hulux tranz
Re: vg30 v6
I'm guessing you mean the transfer case is the wrong side? If so then I'd look at maybe using a Patrol/Safari transfer case. I'm not sure if it does fit but worth looking at as the Safari is a stronger version of the Terrano trans so it all might bolt together and the front output is on the right hand side. (opposite a Terano)
FYI the 300zx vg30 auto is the same as a Terrano and the 300zx twin turbo auto is the same as a Safari.
Re: vg30 v6
hi what you puting it in to? Im doing the same puting a vg30 and geaqr box out of a terrano into a suzuki 410 and we have the same prob. I was just going to change the frount diff head over. I have herd that the terrano gear box is quite strong.
Good luck with that...
Re: vg30 v6
was going to do the same as what you are doing, but found that if you turn the diff over the axles are only spun one way, therefor it may break axles cvs a lot easier just my thoughts tho . I have know found that a nissan cedric auto bolts up going to run a toyota transfer box .in a nissan safari rolling chassis with a suzuki body on top .
