lpg 2jz hilux not running
hi all
got my 2jz running in my hilux, was pritty mint, now can spin the wheels on the tarmac.
Tthen i wired in the alternator and the problems started
now its hard to start and when it does it just stalls after few seconds, its got spark and lpg flowing
the dizzy came loose but iv tryed it in lots for different postions and still the same.
anyone got any ideas?
scott
0211203155
scott
0211203155
1991 Hilux ,solid front axle ,3.0 2jzge,crane
Re: lpg 2jz hilux not running
So was it after the alternator being wired up or the dizzy coming out that it stopped?
How many volts have you got? Should be pretty easy to pull the cam cover and time the dizzy back in properly. Pull the plug on the alternator and you should be good to go if that is the problem.
Matt.
Matt.
both happened at the same time, its just the retaining bolt for little ajustment on dizzy, yea i tried puling the plug but still no good
thanks
scott
thanks
scott
Have you retimed the dizzy properly?
Have you got enough volts for the motor to run properly? Often if the voltage is low the motor will crank and catch but not start properly if the ECU isn't getting enough voltage.
Matt.
Matt.
sort of, ok i will check the voltage it might be low
thanks heaps
thanks heaps
- Sadam_Husain
- Angry bird
blulux wrote:sort of,
I thought that needed a YES or NO answer
i mean i think i have fixed it, checked the voltage and its 12.57v it will start but then it stalls right away
Does it actually start and run then stall or does it catch and stall?
If it's catching and stalling it has to be dizzy timing or you do actually have a fuel problem under load.
Matt.
Matt.
ok got a timing light and got that sorted, still not starting, any ideas?
So whats it actually doing? You say it's starting then stalling, now you say it's not starting.
You need to be a bit more descriptive with the problem if you expect people to help you remotely over the internet.
Matt.
Matt.
ok sweet
its the same as it was before i fixed the timing it is hard to start ,then it does but only for a few seconds, then it stalls, its hard to explain sorry for the little detail
scott
scott
Is your fuel pump strong enough to crack the EFI system back pressure?
I had to get a decent, high pressure pump to run the fee8 as the crack pressure on the fuel injection was more than the pump I was using could deliver. It would start and run, but as soon as you loaded it in any way, it would die.
*edit*
Opps my bad
(didn't take any notice of the LPG part of the title)
*edit*
Opps my bad
its not the ballast resistor is it?had a similar fault on a car.It had full 12volts on starting & 6volts when running to save dis points life.is their power to the disy when key turned onto the run position?
It's either compression, spark or fuel.
You need to be 100% that the dizzy is timed correctly - hard to start is often a timing problem but it could also be fuel.
I have no experience with LPG so can't really advise there but I would be looking to use a fuel substitute to see if it starts and runs if you are sure that the dizzy is set correctly and that each plug is firing.
Easy to check each plug, pull it and sit it against the engine block and crank it.
Matt.
Matt.
