vvega wrote:KiwiBacon wrote:vvega wrote:you wont blow anythign out the seals are designed to grip the shaft harder with more pressure
you will however increase shaft wear
Go put 10psi into your diff and gearbox breathers. Take photos of the ground before and after.
Any extra pressure will push the seal lip onto a slightly different part of the shaft. Unless that part is completely clean, ungrooved and free of corrosion then it'll start leaking.
Show me a 4wd shaft which is clean, ungrooved and corrosion free.
i have a pile of spares that arnt .....
i spent 5 years in hydraulics rebuiling pumps,motors,rams and repairing broken shit so i saw it everyday
i know for a fact your wrong
your talking .5 or less of movement with 10 psi and disputably it probably wont even shift at all if the you have factory steel backed seals 10 psi ant #### all
if the seal and shaft are in good condition it wont leak if your seal or shaft are damaged then .. its not the pressure making your shit leak its the fact its fucked
oh and my diffs and shit wont leaks ... why because ive just rebuilt them and the surfaces are like new and the seals are brand spanky
perhaps you should be doing more maintance on your own gear if this is a issue for you
Hydraulic seals and diff/gearbox seals are a world apart. The seals on your average diff or gearbox won't take kindly to an extra and unnecessary 10psi. Given that a mere 2psi of pressure can already push water past the seals then they are far from in perfect condition (few used 4wd's parts are).
