I'm a long time reader first time poster.
Ive been reading some posts about boosting up a 2LT, some ppl saying 10psi, some saying 16...
Im running 25.8 and quite happily for some time!
Engine is 2LTE Series 2 with standard CT20 turbo
-2LT Series 2 injector pump, modified compensater, wound up fuel
-3inch turbo back exhaust, straight thru muffler
It gets up and goes alright, max EGT is 450 (can't complain with that!) cruises 100kmhr at 250 degrees
So yea anyone keen on boosting up a hilux, go hard and if ya wreck somethin... it only gets replaced with something stronger
And for anyone interested in rest of truck specs...
LN65 Double cab
35x12.5 Creeper Crawlers
15x10 Black spokes
2 inch lift leaves
extended shackles
2 inch body lift
Rancho 9 way adjustys
LSD in rear
TJM front bar
Safari Snorkle
Skyline seats
Boost, Oil press, Water temp and Pyro gauges
Lightened Cro-Moly flywheel
Brass button clutch
LN130 Gearbox
1 Piece rear driveshaft
And the best bit.... REG WOF CERT RUC!!!
