lexus V8
For all Suzuki related topics
mate
Stropper
lexus V8
Post by mate »
HI every1
i am thinking bout putting a lexus v8 into my sj410
is it possible?
i want to find out how much it would weigh
also what gear box would i need to use?
would use toyota diffs as there already sittin in the shed
whats the easiest/cheapest way to mount the diffs?
niblik
Post by niblik »
welcome aboard 'mate'... heh heh..
be interesting to see that in action, if possible..
good luck. :wink:
swampa
Post by swampa »
mike at 4wd upgrades in chch has done one into a 410 flatdeck, heaps of work.
De-Ranged
Post by De-Ranged »
Gidday Mate :lol: sorry couldn't resist :roll:
I'd ditch the zuk box and go over to a W or G series 5 speed lux box, your truck would be so light you wouldn't need anything heavyer
They are also easy enough to get adapters or bellhousings for (just run a search on trademe) just cost a bit is all (still less than a custom bellhousing!)
Are you looking at road legal or not ?? as leaf springs would be the easyest to get legal... they've tightened Low Vol Cert on coil linkage systems :roll: if not go the coils :twisted:
If you go ahead with this :D lots of pic's !!
Cheers Reece
mate
Stropper
Post by mate »
hi
Sounds like hard work not to mention expensive
mite have to use different motor
Any Suggestions?
Was thinking suzuki 2.5/2.7 v6
am thinking about using yj wrangler springs
Do i have to use the hilux g box/t case with toyota diffs or can i use the stock t case?
Cheers Adam
Clint
Post by Clint »
Anything is possible. Just add time & money.
A whole new drivetrain is definitely required, a gbox-tcase out of a 3 litre turbo hilux or surf with an adapter is the best solution. Leaf springs would be easy but on such a light vehicle with so much power you would have big issues controlling axle tramp & retaining enough flexibility. Coils are the ideal.
A big project, especially if it's gunna be road legal but would be a very cool rig if done right. I think the weight would probably be in the 1400 - 1500kg range. I was thinking about doing the same thing but I couldn't find a decent body & chassis at the right price so I went for the Prado Cruiser which already has decent diffs, brakes, gbox, tcase, suspension to build off.
mate
Stropper
Post by mate »
Hi Clint
Do you know what the model no. is for the hilux g/box t/case
is this the adapter plate you mentioned?
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Toyota/Engines-drive-trains/auction-57013525.htm
How would i use coils legally?
i got my sj410 for free it was my dads.
Cheers.
Adam.
De-Ranged
Post by De-Ranged »
Yep, theres also somebody on there who has made up a custom bellhousing but its $500 :(
The issue with coils is they have just changed the rules in the "Low Volume Cert" and made it tougher to do :roll: I haven't looked at it too much yet as I'm working on other problems, basicly they've decided that linkages have to be solid... no welds
I've only glanced at it and it would help if they wrote the blastard rule books in english instead of this "legal'es"
Have a chat with Steve(supralux) I remember him complaining about this, somewhere else onsite so its my guess he's a bit more clued up
Cheers Reece
redzuki
Post by redzuki »
if you don't end up not using the standard sj410 transfer case in you project id be interested at the right price just pm me if you want to get rid of it .
jamie
swampa
Post by swampa »
prado auto bolts straight up, as for coils, use factory ones, on my hilux we used prado front arms, safari panhard rods and in the back we used safari arms, making your own is way cooler but 10 times more difficult to get certified
hiriklux
Post by hiriklux »
they changed the steering rules too no welded parts on high pressure side but factory welds are accepted so look for long arms off a standard vehicle i think nissan or isuzu have long arms on coily ones :D :D
SupraSurf
Post by SupraSurf »
mate
Stropper
Post by mate »
HI every1
Thanks for all the help!!
i think ill do it but it'll have to wait till where in our new house and ive got some room.
Just 1 more Q
Would the coil kit that rocky-road make work?
it seems alot easier than making my own
Cheers all
Return to “Suzuki”
