A pair of these CNC machined spacers is needed to adapt either your current solid axle rotors and calipers, or the upgraded IFS calipers and FJ-60 series vented rotors.
We supply all needed hardware to bolt this spacer to the rotor. Dowel pins are no longer used as the adapter has a pair of dowels machined into it, to use factory holes in the disc. The kit includes 6 bolts to mount disc, and is yellow zinc plated for corrosion protection.
$485 inc gst Purchase from our website http://www.snr4x4.co.nz
