whos knows what water temp this should run at, was in the average and the max???
any help would be appricated
water temp on 1600 16v motor
Re: water temp on 1600 16v motor
well I have a 8v 1600 and it runs at a solid mid temperature all the time, well once i had the thermostat replaced as it had 5 holes drilled in it. but it has never go above that.
hope this helps?
Lincoln
hope this helps?
Lincoln
- joeninetynz
- Driver/Navigator
Just figured out my water pump has just $hit itself this weekend.
Dirty Bugger!
Ours runs about 85/90 around town and about 90/95 on the track
