Garage clean-out has the following items offered for sale to ORE members:
- 2 x 4.88 (2pinion/non-LSD) Toyota 8" diff heads. Very good condition. Price $580.00 FIRM for pair. SOLD
"The most common Toyota diff is the 8" standard. It is used in the rear axle on '79-95 (96?) 4WD trucks and 4Runners, and 3/4 and 1 ton 2WD pickups, and it is also used in the front axle on 79-85 (solid beam) pickups and 4Runners."
- 1 x Toyota Hi Pinion 8" diff head 4.11 ratio from landcruiser VX80 Series front end. Very good condition. Price $550.00 FIRM.
"The 90-97 Landcruiser (FJ-80 and FZJ-80) uses a high pinion, reverse-cut front diff based on the V6/Turbo rear diff. The high pinion design allows the steering on these vehicles to run behind the axle and under the driveshaft. Carriers (i.e. lockers, LSD's) from the 8" V6/Turbo diffs can be installed (direct bolt-in) in the hi-pinion diff. The entire diff is also a direct bolt-in to all front and rear axles that use an 8" diff.
This diff is desirable to some straight-axle mini-truck and 4runner owners for a couple of reasons. First, the reverse-cut design of the gears is stronger than simply using a rear diff and gears up front as the factory did since its not using the weaker "coast" side of the gears when driving forward. For this reason, this diff is generally only used in the front axle. Second, the hi-pinion design gives very good ground clearance for the pinion and driveshaft as well as improves driveshaft operating angles."
PIckup or buyer to arrange and pay for freight; can drop off at a transport depot in Christchurch.
Please PM for contact.
More Toyota parts, recovery gear, ICOM UHF CB, etc, coming soon!
TOYOTA DIFFS 4 SALE (SURF/HILUX/LANDCRUISER)
Leithfield
Re: TOYOTA DIFFS 4 SALE (SURF/HILUX/LANDCRUISER)
Hang on Kev, I know Lawn Bowls and Cycling are the "in" pastimes
, but you an't going to fit a bicycle and long shorts and sandals on the green won't cut it
. Don't be to hasty
YOUR A 4WHEELER,
FITZY.
YOUR A 4WHEELER,
FITZY.
Leithfield
Merely a hiatus until the kids get a little older and I have a little more free time Smokey.
Time for new interests and new pursuits in the interim ... or is it a mid-life crisis.
Shit Kev, what am I gonna do with the two full width, heavy wall chromolly, heat treated Diamond Axle housing's I ordered in for ya?
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Leithfield
Very cruel to tempt a man like that Jaffa.
