if any one has the shearpin part of a cruiser pto driveshaft yoke lying around and wants to part with it please let yourself be known to me .was helping a mate get his 11 metre bus unstuck (back wheels fell over a bank) when my pto yoke decided to part company with my winch @#$%^&*( amongst other words)and now am in need of one .uj came apart and said piece flew off never to be seen again . cheers guys
I've got the loan yoke here if you need it, the universal in its farked though..... might be some time before I ever get round to sticking the PTO on my truck
finally got it out after jacking it up and blocking the rear wheels ,combined with the winch tension it got out .took a while .it got stuck at midday and we finally got it up the drive at 7pm
I use an m4 cap screw as a shear pin, and yes it does break first, drove off with pto still in after a winch the other day. They are cheap and I always have a few spares in glove box. Would have thought the bus was way to heavy for any winch, a block or two to reduce the load may have saved the damage.
had a block on it also had bus driving but alas still wasn,t enough ,started to lift the front of the bus off the ground.talked to my mate at toyota parts today about a new one .ex japan with at least 4 zeros for a complete shaft so tm trolling i will be
i have some toyota PTO driveshafts lying around in my shed came with the winch me and wopass bought he wanted the PTO i wanted the winch and somehow i got the driveshafts as well
my 4wd is not a truck
just had a look around my shed found the driveshafts then realised you want the bit on the shaft going into the winch the winch itself is in yoricks shed will have a look and see what i can find
had another measure up and using the driveshaft yoke means i can make it a bit bigger around the sides.so i,m keen on your driveshaft and it gives me a uj as well .how much cash or beer cheers sig
wopass wrote:ive got a V6 vitara drive shaft with the slip joint on mine. just made some adaptors to bolt it onto the other flanges and its awesum strong
can find some pics of it if you want?
i think the bit he is missing is the flange piece on the worm drive shaft going into the winch does that make sense things would make more sense with pics
mercutio wrote:i think the bit he is missing is the flange piece on the worm drive shaft going into the winch does that make sense things would make more sense with pics
you are on to it sadam .the bottom piece in the photo is what i need but after having a bit of a measure if i use one of the yokes off the middle driveshaft uj i can make one with a bit more meat on it so hopefully will be a bit stronger.silly thing is have got a complete spare pto winch ,driveshaft and pto unit that i got off basics mate over the hill .but just did a deal with it for a pair of 80 series 3.7 diff heads last weekend
