2L not firing
- wgtnnewbie
2L not firing
ok well this started about 4 weeks ago really i moved the blizzy from the drive onto the verge so it was out of the way and when i started it that time it took ages and gave off a lot of white smoke from the exhaust that smelt very waxy.Roll on to last weekend and i decided that i should clean the truck and move it back up the drive, but when i went to start there was nothing it just turned over but didn't fire. (managed to flatten the battery in the process)
after asking a couple of guys we figured out that it was the glow plugs....so finally fitted the 4 new plugs this weekend and hooked up the car to jump start the blizzy once again nothing dunno if needed more omph with the jump start or could there be another niggle somewhere.
any help would be great guys
cheers steve
cheers steve
Re: 2L not firing
wgtnnewbie wrote:ok well this started about 4 weeks ago really i moved the blizzy from the drive onto the verge so it was out of the way and when i started it that time it took ages and gave off a lot of white smoke from the exhaust that smelt very waxy.Roll on to last weekend and i decided that i should clean the truck and move it back up the drive, but when i went to start there was nothing it just turned over but didn't fire. (managed to flatten the battery in the process)
cheers steve
I would charge the battery for 24 hours then have another go, had a work van a few years ago that the boss was too tight to replace the battery and it was a #### to start but with new battery was easy
- skid
- Tyre Man
Re: 2L not firing
haynzy wrote:I would charge the battery for 24 hours then have another go, had a work van a few years ago that the boss was too tight to replace the battery and it was a #### to start but with new battery was easy
can help with that for ya if needed
- wgtnnewbie
Re: 2L not firing
probably not a stupid idea....lol wonder if skiddy'd got a charger at his place.....lol (be a funny kinda battery salesman if he didn't i suppose)
snap was just gonna pm ya about that
skid wrote:haynzy wrote:I would charge the battery for 24 hours then have another go, had a work van a few years ago that the boss was too tight to replace the battery and it was a #### to start but with new battery was easy
Re: 2L not firing
did ya plug the power back onto glow ribbon....................
WARNING:
- wgtnnewbie
Re: 2L not firing
taz01 wrote:did ya plug the power back onto glow ribbon....................
yep all connections that i took off i reconnected so guess we'll see after charging the battery
Re: 2L not firing
on the post they bolted to ........2 wires 1 top 1 bottom with insulator bit in there too????????????
WARNING:
Re: 2L not firing
I would put straight power onto the glow plugs as it could be the relay craped out , if it starts then you know its the glow relay
- wgtnnewbie
Re: 2L not firing
taz01 wrote:on the post they bolted to ........2 wires 1 top 1 bottom with insulator bit in there too????????????
nope didn't see them...lol there is a connection on the 3rd glow that leads away to another terminal which may be the one your talking about but that just stayed connected to said terminal while ribben was off.
Re: 2L not firing
Chopper01 wrote:I would put straight power onto the glow plugs as it could be the relay craped out , if it starts then you know its the glow relay
ditto i had the same thing
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
- wgtnnewbie
Re: 2L not firing
i take it you mean run the jump cables from battery to the glow plug ribbon
Re: 2L not firing
wgtnnewbie wrote:Chopper01 wrote:I would put straight power onto the glow plugs as it could be the relay craped out , if it starts then you know its the glow relay
yea thats right put a jumper cable off the + and put it on the glow ribben but make sure its on the steel not the rubber coated bit , count to 10 and try and start it
- wgtnnewbie
Re: 2L not firing
Chopper01 wrote:wgtnnewbie wrote:Chopper01 wrote:I would put straight power onto the glow plugs as it could be the relay craped out , if it starts then you know its the glow relay
cool will give that a try once battery is charged fully
Re: 2L not firing
haynzy wrote: I would charge the battery for 24 hours then have another go,
XX Snip XX
I agree ... I found that because the glow plug controller keeps the power on the plugs when the engine is cold it's extra load on the battery often makes a cold engine hard to jump start.
Also how good are your Jumper cables ???
- wgtnnewbie
Re: 2L not firing
dazza85 wrote:haynzy wrote: I would charge the battery for 24 hours then have another go,
XX Snip XX
not to sure about 250 amps i think they weren't getting hot at all just mildly warm
- Sadam_Husain
- Angry bird
Re: 2L not firing
wgtnnewbie wrote:but when i went to start there was nothing it just turned over but didn't fire. (managed to flatten the battery in the process)
How old is your battery?
There the date should be on a sticker somewhere or stamped into a terminal, its recorded as a letter and number format, the letter is the month and the number is the year
ie: D9 = April 2009
- skid
- Tyre Man
Re: 2L not firing
Sadam_Husain wrote:wgtnnewbie wrote:but when i went to start there was nothing it just turned over but didn't fire. (managed to flatten the battery in the process)
ie: D9 = April 2009
Go away you
I was gonna go out there and test his one and lie and then get a sale
he said hes buying pizzas tonight after 4.20pm at his whare
lots of them, but hes only allowed to eat lettuce so we gonna chain him to the clothesline for half an hour and he can chew on the grass while we set fire to his truck thingy.
- skid
- Tyre Man
Re: 2L not firing
HEY TARDBE
DO YOU WANNA TELL THE WORLD OR SHOULD SKID DO IT
Re: 2L not firing
Come on Skid this is so not like you
Do tell dude .... Come on dude tell all
- wgtnnewbie
Re: 2L not firing
skid wrote:HEY TARDBE
DO YOU WANNA TELL THE WORLD OR SHOULD SKID DO IT![]()
what the fact that i know feck all about diesel engines or that it actually had a manual fuel primer pump................
tho in saying that after changing the glowplugs it doesn't bellow out black smoke under load.......
Re: 2L not firing
Must of been somthing real simple then, Comon skiddy tell us?
- skid
- Tyre Man
Re: 2L not firing
Bugger it, hes home alone and has not replied himself so I'll embarass him then.
I cruised around to check out his issues. He had removed the battery for me, so I tested it and it seems its a dud, but I have got it on charge all the same, although I think TARDBE is being hopeful.
So I get a brand spanking new battery out of the truck, (which in all honesty is probably going to stay in TARDBE's wee truk) and throw it in.
TARDBE is cranking it over and it wont fire, so we get the trusty can of CRC out and give the old girl a helping hand.
It wants to go but it just wont fire.
Off comes the fuel line from the manual pump to the motor and skid starts pumping. About 2 mins later some diesel comes through from the tank. The hose goes back on and with a few more pumps and a little extra couple of squirts from our trusty can and she fires into life.
leave it running for a few minutes, turn it off and try again.
wouldn't ya know it, she goes. All fixed.
so the moral of the story is...............................
IF YOU ARE GOING TO BUY A 4WD WITH THE INTENTION OF USING IT, THEN IT HELPS IF YOU DO ACTUALLY USE IT
I would mention at this stage that I drink bourban TARDBE, but you have little cash and it seems you are going to have to come up with $125 anyways, so we'll just call a free embarrasment this time
Re: 2L not firing
Re: 2L not firing
Steve, unsure what the engine is in your truck but a real quick search of the net found a manual for the 2L-T. Is this the same as what you got?
http://pdftown.com/Toyota-2L-T-and-3L-Engine-Repair-Manual.html
6.6 MB. If so, download and learn about your engine mate.
~ Good roads lead to bad fishing. ~ Eric Wight, Maine Game Warden ~
