electric fan, what sort??
What have people used as an electric fan. Will be mounted onto FJ70 radiator and be keeping a chev cool.
Darren
Darren
- curly12
Re: electric fan, what sort??
dawwen wrote:What have people used as an electric fan. Will be mounted onto FJ70 radiator and be keeping a chev cool.
Darren
Farken big one!!!
I think the commie ones are the ones to go for, try using the search function
commodore VN or VL electric.
Who knew Prados could fly?
- skid
- Tyre Man
yup, wot they said
had a commy fan and shroud cooling my 40 with 350, did the trick quite nice
- mike
- Last minute Mike
4.0 falcon one. moves a shit load of air. stay away from those super cheap ones as the fins are just useless compared to the car make ones.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
i have a bmw one
sucks in small children ... and has tried it on with me more than once
Kiwi4x4
mike wrote:stay away from those super cheap ones as the fins are just useless compared to the car make ones
Currently going through the decision on what fan to put with the rebuild.
Radiator is a 3 core one from a Mazda van and engine v6 ecotect holden.
Was going to just put a supercheap (or trademe) $120 16" fan. Reading this topic and others seems to be a preference for vn or similar fan over the generic fans. Question is how much better are say the vn fans over a generic fan??
We haven't put the radiator into a position yet so not worried at this stage about depth of fan.
Seems to also be a lot of different opinions on straight fin or curved?? Anythoughts?? Will need to track one down tomorrow as going into truck on friday.
STU
Team Lada Loves Sloppy Holes!!!!!!!!!!!!!!!
generic fan lasted a week in my truck. generic fan was $100 and I replaced it with a $15 commodore one
only snag with the commie is the depth of the motor
i got my fans off a mercedes 300E and man do they move some air have to use the shroud with them to get the most out of them and they are pusher fans
i will admit they are untested on the road at the moment but seeing how they have performed so far i will be surprised if they don't work out
my 4wd is not a truck
- rangimotors
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Performance/Radiators-cooling-systems/auction-214750943.htm
i bought one of these, smaller engine though,
mercutio wrote:i got my fans off a mercedes 300E and man do they move some air have to use the shroud with them to get the most out of them and they are pusher fans
almost the same as my fan ... i onlt have one and it keeps my uz well under control
Kiwi4x4
a electric fan with a good shroud thats covers all the radiator, i am running a honda Vigor radiator with 2 shrouded fans on it, seems to hold onto the temp ok, got ECOTEC v6 supercharged behind it, was told by a radiator place that it would not keep the motor cool.
I have EL Falcon (twin) fans mounted on an ali shroud so that the entire radiator gets air sucked through it.
At Rotorua last year the fans got jammed but wood floating into them and blew both fuses. Un blocked the fans, replaced the fuses and all good.
There certainly shift some air but I'm not sure about small children, as I try not to have any of them around!!!
Cheers for the advise. Have gone with a VN holden one. Figured we have the room under the bonnet so might as well fit the bigger fan that hopefully will last longer. Also only $40 from wrecker compared to $100 odd for the 16" trademe jobbies.
i too think i'll be going in search of a holden fan to.
Cheers for the help
Cheers for the help
- Flyingpony
- Bush Crasher
Also looking at replacing the electric fan on my Series 2a.
I'm assuming in the above posts the electric fan is mounted behind the radiator - i.e. between engine & radiator.
Will those above mentioned fans also work if they're mounted in front of the radiator - mine is front mounted and there's only a couple cm between engine & radiator. Or should I look at other models or can the electricity polarity be reversed and they'll happily run backwards??
Thanks.
Thanks.
The VN I have I swapped the polarity and the blades, so its a pusher...
- flyingbrick
the fan in my GQ is all broken and cracked round the hub..I reckon its from the blades hitting water last time i was out.. hmmn.
What do people do for 24v electric fans?
flyingbrick wrote:the fan in my GQ is all broken and cracked round the hub..I reckon its from the blades hitting water last time i was out.. hmmn.
You'd probably find that the 12v commie ones would last a while on 24v
wjw wrote:flyingbrick wrote:the fan in my GQ is all broken and cracked round the hub..I reckon its from the blades hitting water last time i was out.. hmmn.
You'd probably find that the 12v commie ones would last a while on 24vmight be an expensive test though...
use 2 and wire them up in series then
Kiwi4x4
- flyingbrick
lol.
It'd be cool. If you slowed one down- one would speed up.
wire up to 1 batt with 24v relay and switch
you shold all ready have 24v relay from old fan you can use
