Bolo
2XL
Post by Bolo »
Bulletproof wrote:
Bolo wrote:
What the hell is it?? :?
I called it "Barker 272 special" It was my own design using sheet metal and different body parts and built on a Ford Customline chasis and the 272 motor that had 4 twin throat carbs ,extractors, planed heads and 3 quarter race cam. When pushed it would do 8 mpg but in those days fuel was cheap.
OUR MOTTO WAS " V8s NEVER LATE, 6 IN LINE A WASTE OF TIME"
Cheers Richard
:shock: NICE love it , :twisted: . i want one on order :lol: :lol: :mrgreen:
Bulletproof
Post by Bulletproof »
vvega wrote:personally im not a fan of guages .. i like lights :D
ive set my truck up so it limits when it gets to hot and kills the engine when oil pressure gets to low (not sure if thats a good thing yet .. but its saved my engine once sofar)
have you considered making a mk3 cortina center comsole style guage set ? to keep yourself nice and clear .. with maybe a row of red lights to give fair warning ?
Hi Wayne
I agree that lights will quite often give a better warning but I like the guages because they give an earlier warning.
The pyrometer, Air pressure, and boost have to stay as guages. The oil temperature is good because this is the first sign that the radiator is clogged up with mud. and then I only have oil pressure and water temperature.
They are easily read and out of the way enough even if they look messy so I cant be bothered to move them.
Cheer Richard
Never say die, up man and try
antsarooney
Post by antsarooney »
Hi Richard i have been watching this thread alot and am intrigued by the amount of work you have done.
Wondering about your bullbars whether you built them yourself or bought them if so where from,also could you possibly put up a photo of where your winch is mounted please.
Cheers for the thread.
Ants
Bulletproof
antsarooney wrote:Hi Richard i have been watching this thread alot and am intrigued by the amount of work you have done.
Ants
Hi Ants
The bullbar was on the truck when it was imported. It is a Smittybilt from the USA
I cant seem to be able to really show how it is mounted. I have set it hard back so I still have a good approach angle.
2 bolts go right through the bar and 2 are through plate welded to the bar
The bar is mounted above chassis height so I have tied it along the chassis for extra strength. I have triple blocked off it so has been tested to over 20,000lbs
Hope these help
Cheers Richard
antsarooney
Thats perfect thankyou.
Andrew1706
Post by Andrew1706 »
Richard, while on the subject of your winch, what battery do you use?
Bulletproof
Andrew1706 wrote:Richard, while on the subject of your winch, what battery do you use?
I have a single Hella crankmaster CM1000 cca battery and a 70amp alternator and have never had a winch give trouble with a flat battery or overheating.
When winching I put both lockers in and using 1st gear winch and drive at the same time.
Cheers Richard
philux
Post by philux »
What would the spring be for under the body mount bolt? (Its a spring right :? ?)
Bulletproof
philux wrote:Image
I used to get alot of cracking in the body so fitted holden double valve springs under all the body mounts to allow more flexing. It has been like that for over 5 years now and the body doesn't crack now.
Cheers Richard
albundy
Rolly Polly
Post by albundy »
Shit, I've got that problem, didn't realise it was such an easy fix Richard. Did you just have them laying around or source from wrecker/engine reconditioner.
Al
PR
In the crap again
Post by PR »
I have that same problem :roll: :oops: :roll:
(021) 02388443
but Pr you have body lift on a saf thats normal for a lifted saf :D
PR
In the crap again
Post by PR »
coxsy wrote:but Pr you have body lift on a saf thats normal for a lifted saf :D
Not where mines cracked :oops: no where near the body mounts :roll: :roll:
(021) 02388443
wjw
Post by wjw »
You could always sit somewhere else... ;-)
Who knew Prados could fly?
PR
In the crap again
Post by PR »
Thanks BILLLLLLLLL
(021) 02388443
Bulletproof
My one cracked where the front guards joined the body and straight up above the front guard mounts and at the back of cab by the top of the rear window. They seemed to be the main stress points.
Cheers Richard
PS Hi Al
I just happened to have some commodore valve springs at home and used those. They are the double ones but any valve springs would do. I used 8.8 metre bolts with nylock nuts.
On my first certification they questioned them but then couldn't see why not and they have now gone through 3 certs
PR
In the crap again
Post by PR »
Bulletproof wrote: My one cracked where the front guards joined the body and straight up above the front guard mounts. They seemed to be the main stress points.
Thats where mine has cracked :oops: and not under my seat thanks Bill :?
(021) 02388443
Bulletproof
My hilux "burglar alarm", taken this morning.
Cheers Richard
antsarooney
I have a similar burglar alarm for my hilux just a different model and a bit smaller.
turoa
Pyro Junior
Post by turoa »
Richard, what gear do you normally use offroad (up slippery banks and through bogs etc)?
Bulletproof
turoa wrote:Richard, what gear do you normally use offroad (up slippery banks and through bogs etc)?
With the 35s on I use 2nd in low box for slippery banks and bogs because I have a lot more control to shut off and gain momentum again. With the 35s it is impossble to kill in 2nd.
With 33s I quite often use third but tend to run out of power so 35s work a lot better and give better momentum.
Im still running 4.5 diffs.
Cheers Richard
Shane
Post by Shane »
do you have reduction gears in tranfer case?,I thought some were you said you did but could be wrong?
Shane
Bulletproof
Shane wrote:do you have reduction gears in tranfer case?,I thought some were you said you did but could be wrong?
Shane
Hi Shane.
No I dont. I have the chain driven R15 box that has the lower ratio.
To show the difference Gears make here is a video clip of the steep slippery bank on the No 6 track at Westport.Very few trucks drive this. Out of the 3 last trips only 2 trucks have made it. A couple of trucks have slipped back and rolled here.
The 1st attempt I have is on 33s and 2nd gear, but miles too much power and not enough momentum.
Andi Delis then drives it in the 3.9 V8. I then change up to 3rd and get up but have no power left to shut off if needed.
The 3rd time I am on 35s and 2 gear and with this setup still have heaps of power but also momentum.
Chris Hollis trys in a 4.2 landcruiser with lockers but only gets about a 3rd of the way up.
Cheers Richard
PS Next time Jafa is down we will have show him this track
Bulletproof
I have just found an old photo of the Rough River at the confluence of Mirfins creek on the Westcoast.
Real Jafa country . Big boulders and 1 metre deep water. No one else was game to cross
Higgie and my self on the other side.
Cheers Richard
albundy
Rolly Polly
Post by albundy »
Got a grid reference for the place Richard? Looks like its worth a looksee. :wink:
DieselBoy
Post by DieselBoy »
Bulletproof wrote:My hilux "burglar alarm", taken this morning.
Cheers Richard
Ohhhhh, you gotta bring him up with you when you come to visit the waikato!!!!!!!
mudzilla
Post by mudzilla »
Yeah... 8)
vvega
Post by vvega »
Cheers Richard
man hes a looker
looking forward to your visit richard
also really need to catch up with wayne :D
Kiwi4x4
wopass
Post by wopass »
Cheers Richard
will have to keep Judge chained up... him and sheperds dont get along well... :?
Bulletproof
Talked to Wayne ( Mudzilla) tonite and the plan at this stage is to come up for labour weekend and then stay at Wayne's the next week and do Thompsons etc.
Janet is real keen but wants to leave Klaus (the Shepherd) at home so she can Video the trip and have a relaxing holiday.
Cheers Richard
