Cheers in advance.
Rych wrote:Just interested to know what a common / good lift is for a 97 model Wrangler, would be one that is used for everyday on road commuting but then also decent for off road. And being able to run 33" tires. Living in Auckland and wondering where a good place to purchase / fit a kit would be.
Cheers in advance.
TJ wrote:Richard Brooks at Auckland 4x4 has a Wrangler. I am running their OME kit. He knows a bit about Jeeps (more than most in Auckland). OME kit goes to 2.5", but if you put a lot of weight with armour, springs do tend to sag quickly (ask me how I know).
As for labour, its a simple job and can be done in a driveway. We can even make it a fix Jeep day.....
Rych wrote:Something like this looks good: http://www.wooders.com.au/index.php?mai ... cts_id=522
What would be recommended in terms of shocks, I'm assuming you cannot run these systems on factory shocks.
TJ wrote:TJ being a short wheelbase (say compared to an XJ), at 4" lift you will definitely have to address the rear driveshaft. The best way is through SYE and double cardan driveshaft. Other options are transfer case drop and/or engine lift combination. Dropping the transfer case negates some of the original intention (i.e. raising everything away from ground). Double cardan is likely to require an adjustment of rear pinion, hence upper adjustable control arms. On a TJ, if you want to raise it anything beyond 2.5", you have to be prepared for all unintended consequences of going all the way. Otherwise stick with 2.5" which would allow you to comforably run 32" tyres.
I don't know about the quality of ORV springs and shocks, so can't comment. At the end of the day, its your budget and choice. Talk to a few people who are using the kit and see what they say.
xj wrote:ORV are also re-stickered SkyJackers. Ive got them on mine. Contact Greg Hopkins for a $$$$. ("justjeep" on Trademe) He's just lifted his TJ (again) and has used the ORV gear, I actually nicked the shocks out of his kit.
Additionally, when i first got mine it was lifted 5 inches and still had the stock D/S with a 1 inch trasfer case drop. It worked just fine, but would only have been a matter of time before bending the output shaft. Having said that, i know of a TJ lifted 4.5 inches, with SYE and DC driveshaft, and he still HAS to have the transfer case dropped too. Regardless of adjustments to upper control arms or whatever, it wont stop vibing until the transfer case is dropped........
No two Jeeps are alike.....
Rych wrote:I see, I didn't think about the other stuff that goes with it. Could I run 32" tyres with a 2inch lift such as this:
http://www.wooders.com.au/index.php?mai ... cts_id=524
That seems pretty cheap, I guess it won't have quite the same performance on the tricky stuff compared to a higher lift. So standard springs work fine with the 2" lift?
Who could I get to do the extra work needed after say a 3.5" - 4" lift?
PS: Is that what this is: "Note: The installation of a slip yoke eliminator and CV driveshaft on the stock NP231 transfer case is recommended on a TJ."
Rych wrote:Oh ok, I actually have 31's on now. They rub when locked too far though. I'll have to figure out what I want to do. I would rather have a high lift, just depends if I can get that extra work done and how much.
So need to also get these:
http://www.wooders.com.au/index.php?mai ... cts_id=193
http://www.wooders.com.au/index.php?mai ... cts_id=138
Starts getting expensive ah..
Cheers.
xj wrote:Rych wrote:Oh ok, I actually have 31's on now. They rub when locked too far though. I'll have to figure out what I want to do. I would rather have a high lift, just depends if I can get that extra work done and how much.
Cheers.
Regarding the rub. Im picking that the tyre is rubbing on either the swaybar or the upper control arm??? If so theres a bolt on the front of your steering yoke that if adjusted out will limit your lock to the point that the tyres wont rub. Get down in front of the tyre and on the bottom of the yoke you should see it there. (at least thats where i think it is... cant recall off the top of my head.)
TJ wrote:Those bolts are one on each knuckle and normally the rubbing is on the lower control arm.
Rych wrote:Looks like its going to cost me about $3,500 dollars all up to lift 3.5". Bit more than what I was looking at. So there would be no way to get a 3-4" lift for around 2k? Maybe have to go for one of those 2" ones and do a 1-2" body lift or something.
Rych wrote:Yea lol soz..Just don't think I want to spend too much now, want to make sure its what I am going to do for awhile. If I get really into it I could go all out later on in time, possibly next summer or something. I need two new front shocks anyway, so a full set with some spacers could be a good way to go. With the 1.25" body lift, is there any other support modifications which need to be done or can I just leave it with that.
