I have a series 2 VN motor (the fark up)
I'm wiring it up with a series 2 VR loom and computer as I have the VR electronic kickdown auto box (No other option really as I bought this first)
I have 99% of the plugs plugged back in bar 2...
One is a 3 pin plug located in the loom by the oil pressure and oil pressure switch? I believe it to possibly be a knock sensor? It has a brown wire, a white wire with a red tracer and a white wire with a black tracer. What is this plug for (I cannot find where it plugs into) and on the VN loom it doesn't have this plug at all. Will I be able to run it without this?
The second is the 02 sensor. The VN headers never had one, but they do have a hole with a bung in them to take one. I have got a 02 sensor but it has a different plug at wiring colours, possibly because the sensor I have may be off a even later model motor (possibly ecotec). Do I really need the 02 sensor lol. I no it could run rich.....as long as it doesn't run lean I don't really care i'm not going for fuel economy with this bush basher beast
HELP
