hi, I am running a 50mm suspension lift in my saf, I have put spacers under the box cross-member which has made things a lot better but am still getting a slight grumble at around 60-70 km/h, i am going to put 33's on this weekend, would i be better off with drop boxes?, also it is a auto which the previous owner put a after market trans cooler in, it has this funny looking (what I would say is a filter) just before the cooler it self, is this normal? as it gets quite oily and was wondering if it could be removed.
any help appreciated
50mm suspension lift in swb saf...
Re: 50mm suspension lift in swb saf...
check to see if u joints are paraell, first 33'' will not change drive shaft angles, a prefilter or extra filter will not hurt your trans but if you need to lose it will be fine
