As the title says, What grease do you use in the following applications? And the cost.
(1) Wheel bearing
(2) Swivel Hub
(3) General - everyday use ect if different from above
Also where is the best place to get it.
Last stuff i used was Castrol LMX from CRT cost around $8 a tube i think
Cheers.
What Grease do you use?
toymota thats stock standard.
- mud_slinger
Re: What Grease do you use?
for wheel bearings i'd use wheel bering grease
needs more curry
0272593533
0272593533
mud_slinger wrote:for wheel bearings i'd use wheel bering grease
Thats helpfull cheers hamish... Hurry up and get the mu going lol
- Sadam_Husain
- Angry bird
Shell Retinax LX2 High temp grease, retail 8-10 bucks a tube
Marine Grade that I brought from Saeco bearings about $11 a tube but hew I like to swim
(021) 02388443
(021) 02388443
Morey's EP2 is the best for most applications except wheel bearings and CV's. It is the orange extremely sticky stuff. Not cheap but at about $15 a tube it is all realative. Water proof and extremely resistant to wash out.
Wheel bearings CV just use a good brand Moly grease.
Went with Castrol LMX again. CRT has it for $7.12 for retail 6.98 if your a shareholder
alot cheaper than the 14-16 asked by repco
