Noticed the rear spring perches had collapsed and the axle housing has been rolling around inside the U-Bolts
Diff
Perches
Sadam_Husain wrote:Pulled out the broken rear diff from rallywoods a couple of weeks ago, got another C&P to fit to it, found a few bruises around one of the cross pins but other than that it looks ok![]()
Noticed the rear spring perches had collapsed and the axle housing has been rolling around inside the U-Boltsso getting them rebuilt while the diffs out
vvega wrote:did you break a 9" diff sadamm ?
Turoa wrote:it only happens when there is axle wrap and by the looks of the spring perches, that looks like what caused it
Bulletproof wrote:That is one area to watch on an ARB. The short pins on mine are flogged out and loose.
I put spacing shims in mine to take out the slack by the block in the middle of spider gears
vvega wrote:im bout to put a 9" in mine mate hence my concern
arh well .. no going back now i have about 3 diffs 4 axels and a pile of bits
Sadam_Husain wrote:vvega wrote:im bout to put a 9" in mine mate hence my concern
9 will be heaps stronger than an 8, thats the first 9" diff I've popped in 20 years and if you look at the pics of my spring perches you'll see how much my diff housing and pinion rotated before it sheared![]()
skid wrote:and its not like it was a hard hill or anything
you probably been up there shiteloads in the past![]()
Sadam_Husain wrote:
Its the long pin that goes right through
vvega wrote:on i side note
today i learnt that
electric 9" lockers need a long spline axle on the short side
that you cannot buy one of these off the shelf
and that a man down in welly will make one for 150 bucks inc (i couldnt make one for that inc heat treatment) and like jafa you need a hub plate to make it all work
also
that a rear diff bearing set is $490 retail(but who pays retail)
that the electric locker requires a hard shim set .. hasn't got the adjustable side plates
and that its bloody heavy to drop on your foot
i also learnt that the motors are fixable![]()
and that actually fitting the axle to the truck takes 2 hours
and is impossible to do when your diff hoops are in auckland because you forgot to take them out of your flatmates car
man what a weekend
