Using air con for compressor in fj40
Hi, can any1 help, My mate wants to use a air con pump as a compressor in his fj40... what is best way to run it? because not really to keen to run waterpump, alternator and air con off 1 belt from the crank. but cant seem to find a twin crank pulley..has any1 done this conversion and tell us the best way to go about it. thanks guys
Re: Using air con for compressor in fj40
James here, The 40 I got off Curly has had that done.
This is the only picture of the engine bay I have unfortantly, But the aircon pump can be seen behind the battery and Washer bottle.
I'll try and get a better picture tomorrow If no one else get's here before then.
HI, Im the mate with the 40 trying to do the aircon thing.
would be good to see how its hooked up and mounted. Thanks for your help
Can you tell me if they were all running off the same belt??? It looks like there is just the 1 belt in the photo. thanks
- Sadam_Husain
- Angry bird
The 3f motors came out with twin belt pullys
will do so as he wakes up travels 12km to where the truck is takes photos and return back here tonight some time
his dad
his dad
TWO VIEWS FROM THE TOP OF THE ENGINE
thanks heaps for that...making a bit of sense now!
