filter light
filter light
The filter light came on in my 70 and it died
It wont start but when you cash start it runs but when you put your foot down there's nothing.........
Its a 3b So if anyone can help that would be great thanks abbo..
Don't have 4wd.
Re: filter light
Sounds like you have got water in the filter for the light to come on, have opened the drain valve on the bottom of the filter.
Regarding running but no grunt, sounds like a blocked fuel filter, could be the filter in the engine bay or the one in the tank on the end of the pick up.
Have you used any biodiesel as this can cause any gunk in the tank to be disolved into the fuel and block filters.
Thanks
Tim
Thanks
Tim
Re: filter light
suzolla wrote:Sounds like you have got water in the filter for the light to come on, have opened the drain valve on the bottom of the filter.
Thanks
Tim
Ha there no i havent open drain value but will tomorrow. I was thinking it my have been fuel filter. Not to sure the last time they been replaced.
I have just run normal diesel in it. Thanks very much will let you no
Thanks abbo
Don't have 4wd.
Re: filter light
so how did you get on Abbo does the beast live??
- skid
- Tyre Man
Re: filter light
do yaself a favour dude.....................
http://www.offroadexpress.co.nz/Forums/ ... 17&t=16328
go on, BUY IT
go on, BUY IT
- curly12
Re: filter light
Bolo wrote:so how did you get on Abbo does the beast live??
Went around yesterday and drained the fuel filter, is blocked up and needs replacing. Plenty of fuel being sucked through to the engine but yhe pump can't even force any fuel through to the fuel line to the engine.
Re: filter light
curly12 wrote:Bolo wrote:so how did you get on Abbo does the beast live??
- skid
- Tyre Man
Re: filter light
Bolo wrote:![]()
Righty ho , so new filter time
maybe thats why the filter light came on
Re: filter light
skid wrote:Bolo wrote:![]()
maybe thats why the filter light came on![]()
Maybe
Re: filter light
And SSSSSOOOOOO does it live????
