This is an OEM style, 27-spline birfield made entirely out of 4340 chromoly material. The material upgrade makes this birfield much stronger than stock.
This is not a comparable product to Longfield cv's, and shouldnt be thought of as a cheaper version of a Longfield cv, its a upgrade from a stock cv. This will fit your stock axles and is a direct replacement for a stock cv.
$220 each
Note: All Trail-Gear products carry a one year warranty against defects. This warranty covers defects in material and workmanship. An example of a covered defect would be a missed machining step that prevents installation or a significant internal material void. This warranty does not cover normal failure or breakage that is typical when using stock joints in extreme conditions. 4340 Chromoly Birfield joints will not hold up to extreme usage with oversized tires.
