Glow Plugs
Landscaper
Glow Plugs
Post by Landscaper »
Can anybody tell me why my mazda bounty eats glow plugs with in 6 months from new ?
Thanks
Bulletproof
Re: Glow Plugs
Post by Bulletproof »
Landscaper wrote:Can anybody tell me why my mazda bounty eats glow plugs with in 6 months from new ?
Thanks
Check to make sure they are the right voltage for the controller.
Cheers Richard
Never say die, up man and try
tweake
Re: Glow Plugs
Post by tweake »
and your not just replacing them with cheap crap. i know a fair few guys that have had problems with cheaper brands not lasting long.
edit: are you replacing them as a set or just the ones that blow?
i normally just change them as a set. once the first one or two go the others usually blow not long after.
Landscaper
Re: Glow Plugs
I replace all 4 tested the old ones 1 was working just payed $150 for 4 at ripco only place open near me.
the brand was HKT Corporation made in japan are they any good same as last set i hope they last longer.
tweake
Re: Glow Plugs
Post by tweake »
i don't know the HKT's, last ones i used where NGK.
incidentally i just ran into a snip of info on the net saying some of the Ford/Mazda diesels had a habit of burning out glow plugs, possibly from excess temps. they are also prone to cracking heads.
if thats sounds familiar then possibly look at way to decrease EGT's (block EGR, big exhaust etc).
Landscaper
Re: Glow Plugs
Funny you should say that just had a overheating issue a few months ago are you saying high temps stuff glow plugs ?
rxsmiddy
Re: Glow Plugs
Post by rxsmiddy »
i herd they eat glow plugs aswell, big bore exhaust to try bring your temp down abit, if its hot enough to crack a head it could do damage to your plugs aswell
