3L turbo boost pressure
Sanchez
Post by Sanchez »
Not really offroading related, but what's the factory boost on these and is there any scope for upping things a bit without doing the exhaust and/or running into fuel supply problems??
Keen to get the surf down the quarter at some stage - ha ha..
krawlr
Post by krawlr »
well for a start what do you mean by a 3l? 3litre/ or 3l engine
or i guess you mean a 1kz-te/which is 3litre..........10lb max without a bigger flowing exhaust system...otherwise shel be a trip to the doctor from a severe burn.
good luck
:wink:
Sanchez
Post by Sanchez »
So where abouts do they sit from factory, I'd guess 5-6 psi? Much benefit from the extra few pounds boost or you reckon a bit of a waste of time? cheers.
krawlr
Post by krawlr »
hey mate you havent confirmed the engine type....
is it a 1kz?
Sanchez
Post by Sanchez »
sorry mate, yes, the 1kz
krawlr
Post by krawlr »
std boost is around 8-10 psi
uping the boost even 2psi wont do a great deal if anything it will do bad with a std exhaust etc...
ive had a bit to do with these and have got some good power figures from the mods ive done too.
best money spent and noticeable power gains like any diesel get the thing to breathe more.....
2.5 inch exhaust (turbo back)
k&n filter(you would be amazed the power gain at 130-150 bucks)
start with this and then well talk more about boost fiqures and fuel delivery but its the first thing you wana do :wink:
good luck bud
Sanchez
Post by Sanchez »
150 bucks for a filter!!! and if it breathes better than stock it's probably filtering less too...
So you've seen good gains, eh. Out of interest where abouts in the range, more grunt at 2 or will it tend to hold good power a bit higher up instead of dying at 3- 3.5? I reckon if you could hold the same power the standard 3l makes at 2 until 3.5 you'd have quite a sporty wagon.
callum007
Post by callum007 »
slap an intercooler on..
i run a 3.4litre cruiser on 18psi boost. 2.5" straight pipe. no mod to fuel delivery. mass torque increase, revs out lots faster..
and the factory boost warning light acts as a shift light. it comes on at 16psi..
krawlr
Post by krawlr »
yeah it might tell you youre compressor over working but dosent tell you youre egts are skyhigh and youre waiting for a melt down :roll:
callum007
Post by callum007 »
well if it melts, i'll put in a bigger one! been good for well over a year
chrome
Re: 3L turbo boost pressure
Post by chrome »
hey guys, i recently fitted a boost gauge and im geting 12psi in all gears from about 2500rpm. it is unmodified as far as i know and the exhaust is 60mm outside diametre from factory. is this seem high maybe the wastegate is sticking?? or a shit gauge?? its a 1kz in a 94 prado sx
IcedJohnno
Trailer Trash
Post by IcedJohnno »
chrome wrote:hey guys, i recently fitted a boost gauge and im geting 12psi in all gears from about 2500rpm. it is unmodified as far as i know and the exhaust is 60mm outside diametre from factory. is this seem high maybe the wastegate is sticking?? or a shit gauge?? its a 1kz in a 94 prado sx
That's about the same pressure as mine runs (13psi)
Had good quality vacuum & pressure gauge on it for a while after I put my new and ported head on. (Only mod so far) Yes they do have vacuum as you roll off the throttle, cos the butterfly closes.
1rugger
Post by 1rugger »
if you block off the egr valve and remove the throttle butterfly i found mine runs 75deg c cooler exhaust temp on average and am running 12lbs on std exhaust(est2 1/4)with out it getting hot. i am planning on 2.5/3" exhaust, intercooler, mechanical pump & 18-20psi :twisted: :twisted: :twisted: . as from what i have herd if you increase boost & not fuel you cool you're egt & i've heard 18-20psi is achievable depending on how much fuel you put in as not to o/heat the engine & not to exceed 500deg C just after the turbo.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
arbhilux
Post by arbhilux »
i hope you have a soild flywheel or it will slip, im runing 13 psi on my 1 with standard exhaust then went to 2.5 inch and it made it rev out a bit faster the fucked the flywheel going to put a intercooler on it and try put sum more boost into 2 it
Bulletproof
Post by Bulletproof »
The 3L never came out with a turbo to my knowledge. Toyota told me for an after market one on the 2.8 not to go over 7-8 lbs.
Cheer Richard
Never say die, up man and try
zookfest
Post by zookfest »
like callum007 said go the intercooler helps cool intake temps.im running the sane motor as him and my mod list is:
2.5 inch exhaust strait out under drivers door
huge front mount intercooler
k&n filter
big front mounted oil cooler
wound up diesel pump
boost controller runs 10 psi has done for years
these mods were done 1 by 1 and each made a difference
the truck takes a long time to warm up now days and sits on the bottom red mark on temp gauge
im running 36's with big 4.1 diffs and does it no prob
goes good for what it is but its no gtr skyline
Death to the competition
kruza wazza
Post by kruza wazza »
have a 1kzte in my 96 prado, how much more power could i expect from a k an n air filter ? 5kW ? 10 kW ?
philux
Post by philux »
1rugger wrote:if you block off the egr valve and remove the throttle butterfly.
can you tell us more about this? you running the electric fuel pump at the moment?
1rugger
Post by 1rugger »
Yes I'm still running the electric fuel pump. on the back of the exhaust manifold there is a pipe that goes round the back of the engine and goes through the egr valve which is there to keep emissions down by putting hot exhaust gasses into the intake all the time except full throttle. you can simply put a blanking plate on the exhaust side or you can completely remove the valve then weld up & port the manifolds. you can the pull the butterfly out by removing the throttle body and removing the two small screws that hold the butterfly in place. as it is only there to create a vacume to pull exhaust gasses through.there is also a small butterfly to help with engine starting and shut down witch can be removed if you wish. you then get more airflow& turbo comes on a bit earlier :twisted: with a drop in exhaust temps as you are no longer putting hot gas in the intake :mrgreen: you can then remove all the solenoids and the small vacuum hose that comes from the vac pump and block it off at the pump. if you wish to see what i've done you can pm me.
Return to “Toyota”
