70 prado on 33s
70 prado on 33s
will 33s fit on a standard 94 swb prado. if not what is needed bodylift? taller springs??
Re: 70 prado on 33s
running 33's on my current prado, and ran them on my old prado.....both have/had a 2" ome suspension lift.......
Re: 70 prado on 33s
best i save for a lift kit then, who needs a house when u can buy toys
Re: 70 prado on 33s
Bout time we saw some pics of your beastie (have seen a couple of nice shortie prados in welly.....)
cough..... http://www.offroadexpress.co.nz/Forums/ ... &start=345
Re: 70 prado on 33s
I ran 33's on a 93 long wheel base on standard springs with no rubbing, have since done a bit more to it. But go with the 33's be the best bang for your buck. Oh I have the 1kz motor, the smaller 2.4 oiler may struggle with the bigger tyres.
my 2 cents. good luck
Re: 70 prado on 33s
the 2.4 will spin them.......they are just a bit gutless though.....but you can get them bouncing off the rev limiter at 5k which helps
Markr is local with a swb 1kz one, could PM him and see what he has done to his....., or have a chat to Rob at Naenae Tahs .... he might have some suggestions.... he can do the EFS stuff as well...
ARB .... PM Badnuz.... or theres G Guy in town
Re: 70 prado on 33s
You should be fine with 33's, you may need to change the offset on the rims. One thing to check is they might rub on the exhaust in the front drivers wheel arch.. .you won't know till you try some on. It's not a problem with something like an MTR, but with a simex it will damage the exhaust manifold bolts at some point.
Who knew Prados could fly?
- Sadam_Husain
- Angry bird
Re: 70 prado on 33s
Jerry wrote:the 2.4 will spin them.......they are just a bit gutless though.....
I think you meant the 2.4 will turn them not spin them????
Re: 70 prado on 33s
I run 33' Gt radial adventuros on my 93 Prado without a bodylift or a spring lift and have no issues at all with rubbing.
Re: 70 prado on 33s
Jerry wrote:Bout time we saw some pics of your beastie (have seen a couple of nice shortie prados in welly.....)
how do you upload a pic?? its all a bit stock at the mo but i got some plans
Re: 70 prado on 33s
Upload them to www.photobucket.com (set them to 640 x 480 when you upload them) and copy the picture link into a post...
Re: 70 prado on 33s
ive got 31 mudzillas on my swb
- IcedJohnno
- Trailer Trash
Re: 70 prado on 33s
My 32 Simex's, which are in reality a 33, are fine without a lift, unless you try to run chains. Yes I get the rub on the exhaust trick.
There is a nice big red 78 series running in North Canty with a van exhaust outlet on the turbo. This puts the exhaust straight back under the wagon and not out through the side. Problem solved.
