Pintle Hooks
Moderator: Vendors
Pintle Hooks
Hi Guys just got a deal on new Pintle hooks $95 each plus postage Also got the new hitch reciver mounted pintle hook $130 plus postage. Give us a call on 3844141 or pm me to order
Pintle hook bolt on with towball $110.00 plus postage
pintle hook hitch reciver with towball $150 plus postage
Re: Pintle Hooks
Got any pics of them Martin?
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Re: Pintle Hooks
Whats the diff between them Marty, got pictures? Is the hitch receiver one the one with the towball? In that case I will take one
Does it for in the standard 4 bolt "T" shaped receiver?
Benjamin Franklin
Benjamin Franklin
Re: Pintle Hooks
I will put up pics soon one is the standard pintle hook with 4 bolt holes the other is mounted into your hitch reciver there not the tow ball type sorry am working on those
Re: Pintle Hooks
There you go princess just added the tow ball pintles for you
Re: Pintle Hooks
stinky wrote:There you go princess just added the tow ball pintles for you
Still not sure which one is which, I'm guessing it's the more expensive one
Benjamin Franklin
Benjamin Franklin
- flyingbrick
Re: Pintle Hooks
Jezz hang on to your undies dude jerrys got em there comming along with christmas
Re: Pintle Hooks
here are the pics
He can do bike racks and other stuff as well if you need it whilst you are there etc
These cookes strops are good, havent snapped one yet
Towhook thingys
Tree trunk protectors
Rated D Shackles
Winch Rope
Towhook thingys
Rated D Shackles
Winch Rope
- flyingbrick
Re: Pintle Hooks
Whats the story with these hooks and going on club runs? since they are not rated to give way safely they probably wouldn't pass?
Re: Pintle Hooks
Funny you should ask bolt on rated to 8ton hitch reciver to 5ton your tow bar who knows
- flyingbrick
Re: Pintle Hooks
So they could be used in place of a rated tow hook then?
Re: Pintle Hooks
Thats all i use on the back of my nissan but it is a lightweight truck
- flyingbrick
Re: Pintle Hooks
I went to a place today who would sell me a 9 metre snatch strap for $35
will you match price?
im just kidding.. it was trade price. wooo.
-Nathan
-Nathan
Re: Pintle Hooks
No but i might buy some off you unless there those cheap asian ones which my super lightweight Nissan seems to snap all the time
Re: Pintle Hooks
Its all those pies you eat Stinky
Tofu is 1/10th of the weight
- flyingbrick
Re: Pintle Hooks
those pics are pretty-but we need prices!
I'm pretty keen on a pintle hook- the bolt on sort. Guessing you wont sell out any time soon? I've blown the budget this week.
Re: Pintle Hooks
how much for the winch rope.
what dia is it rope and lenght
- Sadam_Husain
- Angry bird
Re: Pintle Hooks
flyingbrick wrote:Whats the story with these hooks and going on club runs? since they are not rated to give way safely they probably wouldn't pass?
Would depend on the paticular clubs how hook policy, I only use a pintle on the back of my truck and prefer it to hooks, the strop cant fall off when it goes slack and being a heavy truck it makes a more even pull distrubuting the load more evenly accross both chassis rails..... oh yeah and stinky reinforced my back cross member with a great big piece of channel
Re: Pintle Hooks
Towball pintle hooks the tow ball size is 1 7/8ths rated to 5ton
Re: Pintle Hooks
Oh yeah baby, Thats the sucker I want, put my name on that
Benjamin Franklin
Benjamin Franklin
Re: Pintle Hooks
stinky wrote:Towball pintle hooks the tow ball size is 1 7/8ths rated to 5ton
so what is the price on the one in the 3rd photo??
- Beer_Cruiser
Re: Pintle Hooks
Can you you get these with a 50mm towball?
Re: Pintle Hooks
yep special order only pm me for price
Re: Pintle Hooks
Just out of interest, if anyone has one and is a 4wd club member, how did you go with the standard "no tow ball tow" rule. Just real curious on how club safety officers see these. I think they are safe as personally.
Al
Al
- skid
- Tyre Man
Re: Pintle Hooks
albundy wrote:Just out of interest, if anyone has one and is a 4wd club member, how did you go with the standard "no tow ball tow" rule. Just real curious on how club safety officers see these. I think they are safe as personally.
Al
apart from the thickness of the pintle part thingy
what exactly is the difference between snatching off this or snatching off ya standard towball
looks dodgy to me
who has one and how hard have ya snatched off it
- curly12
Re: Pintle Hooks
skid wrote:albundy wrote:Just out of interest, if anyone has one and is a 4wd club member, how did you go with the standard "no tow ball tow" rule. Just real curious on how club safety officers see these. I think they are safe as personally.
Al
looks dodgy to me
It is a rated towball, look at the thickness of the mounted towball compared to the one next to it. Somewhere I have a box for one and it stipulates that non factory towballs cannot replace the factory ball
Re: Pintle Hooks
My 10c
The Pintle and towball would appear to have a rating overall of 5 Tons , assuming this is metric that equates to 11023lbs, which is a bit more than a rated 10000lb hook, the "towball" on it is thicker than a standard one, the non towball ones are rated to 8 ton / 17636lbs
Most strops are rated to 8000lb/3.628 ton, The strop will give way first
some recoveries I've seen are people trying to pull the f..k off the hook or break the strop, if a gentle or good strop will not work then its maybe time to consider winching the stuck vehicle out or digging it a bit rather than "excessive stropping".
Mounting of these needs to be considered into the equation as these do not let go like the rated hooks do...., no point bolting it up to the back of your truck if you are using small/factory unrated bolts or there is not enough support behind it......with both my LJ's Stinky reinforced the mount and behind it to support it properly.
Like anything including rated hooks and strops if correctly fitted and/or used these are safe.....
Re: Pintle Hooks
stinky wrote:Yeah wot he said
Yeah dam it. Even I have to agree that Jerry actually makes sense
God that was hard to admit
Benjamin Franklin
Benjamin Franklin
