beadlocks
zookfest
beadlocks
Post by zookfest »
are they worth having they obviously have there advantages.what i want to know is are there any disadvatages :?:
Death to the competition
4WDbits
Re: beadlocks
Post by 4WDbits »
zookfest wrote:are they worth having they obviously have there advantages.what i want to know is are there any disadvatages :?:
Weight, expense, time to assemble/disassemble otherwise essential.
mudlva
Re: beadlocks
Post by mudlva »
just be awere that not all bead locked rims can be used on the road talk to the guy before making them..
of course if you are trailering the vechile that doesnt matter
chers and lol :wink:
cool__bananas
Re: beadlocks
Post by cool__bananas »
brian howat at howat enginnering makes them all the time, his ones are fully legal because they have over 24capscrews or a number like that, if you are getting them get his ones or some other steel one. the aluminum ones are reasonably crap because if they do ever get under too much pressure they can crack. like at the fun trial last weekend some guy had them and one of them broke clean in half (just the aluminum outer ring though) but dont bother spending money on them if you are going to be one of those people who gets them and still wont put there tyres under 10psi or whatever. on our comp and club truck we have beadlocks and we can run them until no more air comes out of the valve :twisted:
De-Ranged
Re: beadlocks
Post by De-Ranged »
Another disadvantage is they are next to impossible to ballance... alot of tyre shops won't bother to even try, so as someone else said treat them as an off road rim
one of the best advantages for me is the bead can't get pushed in when running in ruts 8)
Now for the books certification requires they are built from steel (min of 6mm mild steel for the rings) with a min of 36, 6mm grade 10 bolts, there are a few other bits that must be met but thats the majors
Brian Howat only puts 32 bolts on his.... now some certifiers will cert these becoase this it the only bit he's not up to play on but don't count on them passing :shock: the certifier is taking responsability for these if they break so not to many will do this....
I think 4WD Bits has them for sale and they are certifiable and relitivily cheap :wink:
Cheers Reece
De Ranged Engineering
027 541 8794
zookfest
Re: beadlocks
Post by zookfest »
ive got 35 wranglers on the cruiser now but ive got a highly modded bighorn with 36'' superswampers on steel beadlocked rims im wanting to keep the cruiser and am thinking of swappin them over so im goin to do that.so the supercharged bighorn will have 35'' wranglers
thanks guys
86-surf
Re: beadlocks
Post by 86-surf »
zookfest wrote:ive got 35 wranglers on the cruiser now but ive got a highly modded bighorn with 36'' superswampers on steel beadlocked rims im wanting to keep the cruiser and am thinking of swappin them over so im goin to do that.so the supercharged bighorn will have 35'' wranglers
thanks guys
picture of bighorn plz:D
moonhopper
Re: beadlocks
Post by moonhopper »
there is the option of going to the ARB second air beadlock they go inside the tyre no problems with balancing and they weight alot less than steel, but they cost about $200 each :cry: , a bit pricy though.
albundy
Rolly Polly
Re: beadlocks
Post by albundy »
4Wd accessories in CHCH make their own internal beadlocks. A few locals on the forum down here run them. I'm looking at a set as well.
Al
tpft
Re: beadlocks
Post by tpft »
to change tyres on beadlock rims, is it just a matter of undoing all thoose allen screws first?
95 Safari on brg 33,s/ 4age e class zuk (old faithfull)/ d class rig under construction.
moonhopper
Re: beadlocks
whats the cost on the ones from CHCH i might look at theres if they are cost effective
cool__bananas
Re: beadlocks
if you have alloy 3 piece split rims howy can make internal beadlacks, lots of the trial guy are running them now, and they dont need to be certified because no one knows theres even there
De-Ranged
Re: beadlocks
Post by De-Ranged »
cool__bananas wrote:if you have alloy 3 piece split rims howy can make internal beadlacks, lots of the trial guy are running them now, and they dont need to be certified because no one knows theres even there
8) I'd be guessing these are the same as the Hummer ones with a packer that sits bead to bead inside the rim, if so then there is no cert needed :wink: your not modifing the rim, your just adding something inside the tyre
I've seen guy's on pirate using plastic sewer pipe to make these for there hummer rims as the plastic is lighter, bonus with this setup is it locks both inside and outside beads 8)
This is what I was going to do with mine but modify a set of steel rims to be two piece, removes the fatigue issue of alloy rims cracking and splitting and if I do bend em its easy enough to straighten them :wink: but surprise surprise what I want to do isn't covered by the cert rules :roll: :lol:
Cheers Reece
027 541 8794
De-Ranged
Re: beadlocks
Post by De-Ranged »
tpft wrote:to change tyres on beadlock rims, is it just a matter of undoing all thoose allen screws first?
effectivly yes... undo all the bolts take the clamp ring off and then jump on the tyre to pop it off the support ring (bit that sits under the bead) this is sposed to be a tapper fit so it centers the bead, but not all rims sold have this
the inside bead is just like a normal tyre so you'll have to push this in and then lever it over the lip on the bead lock side to put a new tyre on you just pop it on normally and clamp the outside bead and inflate
The other option is the internal beadlock like the Hummer rims where the rim splits and there is an internal spacer that sits inside the rim and stops the beads poping in, bonus with this is it locks both rims trade off is weight and they can be very auckward to setup as you have to get this support ring in there before you bolt the rim together
The second air system is a real bastard to change without a tyre machine but the bonus is becoase the second air is a mini tube the rims can't cut your side walls if you run fully flat, :lol: I know of a local guy who got home from taupo only to discover he had a flat tire almost two hrs of driving on a flat tyre :shock:
there is one very big bonus with second air systems they work for all bead sizes!!
A word of caution to all those thinking about gettting bolt together beadlocks.... they are made for set bead sizes... this may limit your tyre choice later
Cheers Reece
027 541 8794
albundy
Rolly Polly
Re: beadlocks
Post by albundy »
$699 fitted. He is currently getting some made up. 03 3651909
Al
swampa
Re: beadlocks
Post by swampa »
we are going to run the 2nd air system, as my vehicle is not too heavy we feel we will be ok as we would rather use beadlocks, and we have 17 by 10 steel rims to fit bigger brakes, and a different style of tyre besides the simex's we use now, the 2nd air's do them for 17's and we dont need a cert
cool__bananas
Re: beadlocks
yea, its 2 aluminuim strips tiged together with braces so it does do both sides, put the cage in the tyre, then half the rim on the tyre, then the other half and bolt it up
safari_mulisha
Re: beadlocks
Post by safari_mulisha »
i run 10 inch wide bead lock rims with 14 inch wide 37s
cant wait to get them muddy mine were 23 bolt but are now 46
gary_in_nz
Re: beadlocks
Post by gary_in_nz »
any feed back on the intenal bead lockers?? recommend or not??
4WDbits
Re: beadlocks
Post by 4WDbits »
swampa wrote:we are going to run the 2nd air system, as my vehicle is not too heavy we feel we will be ok as we would rather use beadlocks, and we have 17 by 10 steel rims to fit bigger brakes, and a different style of tyre besides the simex's we use now, the 2nd air's do them for 17's and we dont need a cert
My understanding is that any modification to a rim requires a Low Vol Cert, including drilling an additional hole for a second air valve. How many would notice though.
The current model of internal beadlock is improved over the previous ones, how much improved is unknown. I haven't heard any bad feedback yet.
haynzy
Re: beadlocks
Post by haynzy »
gary_in_nz wrote:any feed back on the intenal bead lockers?? recommend or not??
i got the on my lux and havent had any dramas yet highly recomend them
Swamped
Re: beadlocks
Post by Swamped »
The cert guy I know said you don't need a cert for staun type internal beadlocks or for drilling the hole for the extra valve stem.The stauns are about $200 each i think. would it be cheaper to ship em from oz? They got a 5 year warranty to i think.
swampa
Re: beadlocks
Post by swampa »
if you get them from oz would they be covered by warranty??? better to get them from here through nz distributor and be safe, unless aussie will loook after you
Taz
Re: beadlocks
Post by Taz »
swampa wrote: unless aussie will loook after you
You would probably still have to cover the freight again though to get a replacement/sent fecked one back if the worst happened. Could quickly get rid of the savings, unless they are huge :D
Dr_PC
Re: beadlocks
Post by Dr_PC »
Yep
Return to “Tyres”
