Progress so far:
16 May
Try to unsuccessfully sell the old cage on TM, I've decided to cut out and throw away the old as I can't afford the space associated with storing the old cage so out she comes...
and on with the new, having brought 3 lengths of 48 mm OD tube I started bending things up ...
May 26
I've decided that I wanted to have the flexibility of putting in a rear seat for passengers so I've decided to extent the cage through to the back with an additional rear hoop.
I decided to push out the front top bars to give me some additional head room as I didn't fancy hitting it on the way over
Decided to add in side bars so needed an additional length of tube... must be up to 25.5 meters of steel by now, eek!
Thought this was going to be enough but decided I need to add in a triangle for some strength so I put in a rear triangle and included the top mount for the front seatbelts...
June 4
Just been out to 'Cruiser Spares Ltd' in Upper Hutt to suss out power steering options. They can supply parts for either the FJ60 or the older Cressida conversion. Was considering the Cressida options as it requires slightly less work but having measured up the space between the Pajero PTO up front I may have to go for the FJ60 options... plus they are stronger and parts are more readily available. They were also looking into disk brake options - I'll need to check that they'll fit under my 15" rims as I can be bothered changing my wheel / tyre combination.
I'll post again next time I take some photos... Any comments and/or suggestions welcome.
