Im looking for a FJ40 crossmember if anyone can help.
Ive had a few leads to chase but through Id put the word out here
Thanks Malcolm
WTD FJ40 Gearbox crossmember
- Beer_Cruiser
Re: WTD FJ40 Gearbox crossmember
There might be one on Williams parts truck
Try Warren at Cruiser Spares in Upperhutt.
- Sadam_Husain
- Angry bird
I think they only came out on post 1980 cruisers?
- skid
- Tyre Man
Sadam_Husain wrote:I think they only came out on post 1980 cruisers?
I was going to ask a similar question, but wanted to leave it to more knowledgable chaps
to have the gearbox mounted transfer you need the later model split transfer case ( I think )
give Phil a ring Malcolm, coz he changed all mine over for me, but had to find a different transfer case
- Beer_Cruiser
skid wrote:Sadam_Husain wrote:I think they only came out on post 1980 cruisers?
The plan is to change to a split transfer because they are stronger than the older ones (that what Ive been told anyway..)
It looks like Im going to have to get a diesel gearbox with split tf and change gears to petrol.
Ill need crossmember to hold the gear box in as the old gearbox mounts to the chassie
- Sadam_Husain
- Angry bird
Your old gearbox will only have mounts off the bellhousing onto the chassis so in theory you should be able to do a transfercase swap without worrying about changing mounts. The only thing a bit different on your truck is there is a custom made mount off the back of the transfercase onto the crossmember behind the gearbox.
- 350cruiser
- Driver/Navigator
have a 1982 45 with 4 speed and transfer case with cross member. PM me if interested. only problem is i'm in auckland.
paddy
paddy
doesn't play well with small vehicles
the older transfer case had the hand brake on the back of the case.
if you haven't already done so you will need to sort out hand brake onto the rear axle.
