Guys I have a Gen 1 V6 and having a bit of a stalling problem where giving it hard revs on a hill/dune climb. It seems to cuts out/stalls when I take the foot off the pedal when I cant go any further/no traction.
This has already caused me a nice fender bender on a farm when I went to roll back down the hill and no engine power to slow my decent down !!!!
Had my mechanic look at it and he scratched his head.....does anyone have any ideas on what it could be ?
Gen 1 V6 stalling problem
Re: Gen 1 V6 stalling problem
mmmm4444 wrote:Guys I have a Gen 1 V6 and having a bit of a stalling problem where giving it hard revs on a hill/dune climb. It seems to cuts out/stalls when I take the foot off the pedal when I cant go any further/no traction.
idle control valve sticking?
I looked at that and came up with the conclusion that if it was sticking would it not be stalling all the time/more often??????
It only stalls on a 30 degrees slope coming off the pedal after giving it maximum revs.............????? I will go and play in some dunes in a couple of weeks and see if there are any other clues
Maybe a loose wire or loose fuel pressure problem. I will look in the sticky valve again and thanks for the advice.
No mechanic but sounds like fuel starvation. My current Pajero has done that to me but due to lack of oil/bad sump design
02 TJ Rag Top
mine does something similar hit a steep hill and if i keep revs the same it starts to die makes a pop but if i floor it life is good??
89 Paj, Lwb,V6 3L auto,Snorkel,Ramsey9000lb,31x10.5x15's, flares,breathers, LSD, OldManEMu's,Front Buckys,safety/recovery gear
