is this too high?
For all Suzuki related topics
new2zukes
is this too high?
Post by new2zukes »
well finally got the body on today after i went chop chop and fixed a bit of rust. to me it looks a little tall/tippy but it might be cuz im used to a stock zuke. truck have normal suzuki springs on spring over and 50mm body lift. got hilux diffs and the total overall width is 1770. the hight to the bottom off the sill is 640 and to the top of the sill is 770. its running 31 inch tires but will be running 35s so a little more lift will happen with the tires. few pics of the outcome.
martin
suzookyman
Re: is this too high?
Post by suzookyman »
Hey Martin ,
do you need the body lift?
will measure the scud 2morrow from the sills-you have seen my truck and what it can do on 31s and ifs
catcha, Al
new2zukes
Post by new2zukes »
hey al i was going to run the radiator pipes over the chassi hence why i want 50mm body lift so the pipes dont hit the body. and ye ur truck goes bloody well on 31s sounds nice too :) not like my noisey lil buga mine just makes me def. went offroading today and looked at a guys buggy same sorta princable as mine and his sills sit at the same hight as mine but he is running 35s and has a wheelbase of 1950. so maybe il just drive it and if i dont like it then il put it back in the shed.
thanks.
martin
Return to “Suzuki”
