Hey I own a 1981 bj40, the temperature guage is not working and I was just wondering where the temperature measuring device is located on the engine ( its a B series diesel).
Also whats the best way to test these sensors?? THANKS
bj40 temperature sensor
Re: bj40 temperature sensor
Found the answer to my own question so never mind =)
hey m8, i wouldnt mind knowing.. my temp isnt registering. if you have any advice on where its located would be great.
garic wrote:Found the answer to my own question so never mind =)
Hey yeah it is just under the main water intake pipe on engine (just under the bit where the themostat usually goes in). Should have one wire attached, I measured my sensor with a ohmmeter and it was infinite (which means its screwed) so replaced it today, cost me 25 bux. Took it for a quite drive and it started to measure slightly ( didnt take it for enough drive for it to warm up properly as diff is poached so dont want to drive it much).
Here's a figure which may help.
Butsept mine was on the opposite side of the motor (exhaust)
