spot light
spot light
want to make a spot light rail for the roof of my scud, what make and model should I buy?
I would prefer square rather than round, im thinking about four on the rail
Re: spot light
If you want good light stick to the known brands, Hella, Narva, IPF, Light force etc, The cheap chinese ones just dont have the same ability. They all do rectangular.(maybe not light force)
I have bought Hella commet 500s for $30, IPF SuperRally 930s for $55, smakler IPF super rallys for $30, hella 160s for $30 etc all off trade me. Just have to be paitent. The 930s are $600+ new. I also got a set of Hella FF100s but they were stuffed, risk you take and the guy refunded half the moey plus freight at my request.
Seek and thou shall find.
Re: spot light
mint thanks for the advise
Re: spot light
You could have mounting issues as there is no gutter.Try and find
an Escudo roof rack bar and modify that into a light bar or do what
i did and drilled holes in the roof and bolt my light bar on with wingnuts,when not in use the holes in roof are filled with solid rubber grommits
Al
Al
Re: spot light
where do u get the rubber gromets from?
Re: spot light
Escudo boy wrote:where do u get the rubber gromets from?
Go to para rubber and have a gander. You will be able to find something there.
Re: spot light
Wouldn't having spotlights on your roof give you too much wind resistance for your wee suzuki?? 5000 rpm and 80km/h max speed??
spos I can't talk, mine has the profile of a lifted brick. Anyways autotrail sell narva lights for cheapish and they're real helpful. Could also replace your normal headlights with better ones, might help and be cheaper maybe.
Re: spot light
I'd recommend putting some of that rubber cover stuff on that you cut out and stick on to. They are bound to find some branches being up that high and plastic covers just break or fall off. With the sticky stuff even if you spear your light it will all hold together nicely.
Re: spot light
I had a vine drop down and rip both my lights off...didn't matter what was protecting them.I've seen lights mounted beneath roofrack type things before, that could be an idea.
Re: spot light
Yeah PR has a good setup. Think they are even with the rack but have slanted mesh guards so nothing can catch the rack or the lights. Kinda like the aerodynamic spoiler that sits on the roof of trucks.
Re: spot light
will check it out somtime
- flyingbrick
Re: spot light
Monster (IIRC) has an ABS plastic roof mounted quad spotlight setup thing sitting in his garage which he wants to sell. Same as this (IIRC)
or what about this?
or what about this?
Re: spot light
ur jokes r very hit and miss, this is a huge MISS
- PaulyBoy23
- Bush Crasher
Re: spot light
do you still want to sell that plastic spotlight thing?
www.helensvillepcsolutions.com
- flyingbrick
Re: spot light
Its not from me. Its Vvega's friend on here. Cant rmeember his name.
