2.8d 3L motor rebuild.....damm timing belt
hi All I am new to this site am about to start rebuilding my 3L motor and was wondering if there is anything that i need to be carefull of ?
Munta
Re: 2.8d 3L motor rebuild.....damm timing belt
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
allready got a parts motor(only cost me $220) just looking for addvice for rebuild am thinking i supercharge it( have seent it done) but not sure if it worth it
Munta
if you havnt allready, rotate the motor till tdc and mark where everything is,
its all basic- theres factory marks ect
replace the water pump and idlers when your in there
it would be easyer to turbo it using ln130 2lte parts.
i recon'd and turbo'd my 3L, ive got a workshop manual if you need any torque settings ect
good luck
jeremy
good luck
jeremy
if it looks dodgy replace it, you need it to be reliable not break down on the back country
