2.4 toyota diesel differences
righto then
we have a 2.4 diesel here that we are trying to sell
had a couple of questions we couldn't answer
have searched other forums and a tech website, but not get any joy
what I want to know is the difference between a 2L , 2LT , 2LTE
more importantly, I'm trying to find out what particular model surfs they came in
SKID
or post up any good tech websites you know of
Lynx
Re: 2.4 toyota diesel differences
Post by Lynx »
http://www.toyotasurf.asn.au/
There are 2 styles of 2L series engines : the early ones with the offset cam and rockers up till 1989 and the late style with the direct valve activation from 90 on. The electronic only came on the later stule.
Most of the time the later ones are refered to as 2L2 or 2LT2 or 2LTE.
The early style have a cast aluminim top cover with 3 big nuts in the middle, and a round section pipe crossover tube
Smurf
Re: 2.4 Toyota diesel differences
Post by Smurf »
skid wrote:righto then
SKID
2L non turbo 2.4
2LT 2.4 turbo, 2 different models, early model has roller rocker head, later model has shims/bucket adjusters, both models have different exhaust manifolds, as well as a few other minor differences
2LT-E second gen 2.4 turbo with electronic injection
righto
edited original post coz I forgot to mention exactly wot I was after :oops: :oops: :oops:
Smurf
Post by Smurf »
2l generally a hilux motor, LN65 and similar.
2LT gen 1, in early Surf LN61
2LT gen 2 and 2LT E in LN 130 Surf
Smurf wrote:2l generally a hilux motor, LN65 and similar.
cheers dude
main reason for asking is coz we wrecked an LN130 and the 2L came out of it
but upon trying to sell it as a motor out of a LN130, a couple of buyers have queried it as not being the factory motor
so we just trying to dig up some history
anyone know of a website we can find out engine number codes etc etc etc :?: :?:
Bulletproof
Post by Bulletproof »
cheers dude
Hi Skid
the 1989 LN 130 had the 2LT motor
From 1990 the LN130 had the 2LTE motor
If you lok up ToyoDIY.com it will tell you everything about toyota .Even your VX
Cheers Richard
Never say die, up man and try
I checked out toyodiy
but you need your vin
we only have the motor left
Smurf
Post by Smurf »
Loving the comments on the auction telling you it is a 2LTE.. :roll:
To be a 2LTE it would need a turbo. (Hence the T)
But yeah, I think the 2L replaced the L around 82-83 so LN51- LN60, LN65 Hilux or the first of the solid axle Surfs (LN60) came with the 2L.
Smurf wrote:Loving the comments on the auction telling you it is a 2LTE.. :roll:
yeah, just read that
ya think we'd know if there was a bloody turbo bolted to the side of the motor
some people are real clever though, so we'll just let that fulla think its got a hairdryer on it :lol: :lol: :lol:
Bulletproof
skid wrote:I checked out toyodiy
Hi Skid
You don't need the VIN to identify a motor to a particular model
Look at "Parts reference" -"select model" then skip VIN and go to "Japan" which bring up "Year" And then select model and an older Surf will be under Hilux.
Hopes this helps
Richard
tweake
Post by tweake »
are you sure its not a 3L. ln130's also came out with 3L (2.8) motor.
hosehustler
Post by hosehustler »
Old thread I know but just after a bit of info.
I just bought a LN60 beam axle surf, with a 2L-T, thought it would be a repowered 2L one but body tags clearly show it's original, anyone else come across a factory one of these?
I hate signatures
rokhound
Post by rokhound »
My first surf was a factory 2lt. Some of the very early beam axle surfs (mid '84 and some of '85) had the 2l though.
u13turbo
Post by u13turbo »
hosehustler wrote:Old thread I know but just after a bit of info.
Yeah, mate just bought an 85 ln60 with a 2lt.
crazyclark31
Post by crazyclark31 »
have wheeled with coulpe guys down here with them.
Apparently not that many of them around.
Makes it easier to put a 2lte in.Reckon it the better of the two motors for a dd
Msukefo
Newbie
Newbie
Post by Msukefo »
I've got what I believe is a 2l although it has the 2lt exhaust manifold and turbo on it my question is are the rods the same between the 2l and 2lt I've got a bent rod and a guy sent me a rod supposedly for a 2lt and it doesn't fit?
tweake
Post by tweake »
Msukefo wrote:I've got what I believe is a 2l although it has the 2lt exhaust manifold and turbo on it my question is are the rods the same between the 2l and 2lt I've got a bent rod and a guy sent me a rod supposedly for a 2lt and it doesn't fit?
first thing is do you have a 2l-1 or a 2l-2?
2l-1
2l-2
CORROLUX
Post by CORROLUX »
If anyones still out there on this post...
Just got an 88 japanese ln65 with wat looks like 2l 1 motor. Re the 2l 1 & 2l 2 motors Id like to know if there r any similarities or transferrable bits or setups between each other and or the 3l & 5l motors . Have a few minor 3l bits already but know of some 2l 1 and a 3l partial motor lots for sale. Knowing wat bits swap will help decide whether or not its worth buyn them or not c.
All along been lookn to build up a 3l for a spare for my 3l powered ln106 whichl now get a birthday and its factory diff lock setup fixed n then sold.
So if a 3l was similar enuf in bellhousing & other mounts....push onward & rig a 3l up n drop it in the old ln65 perhaps?...Selling the good 2l 1 to get a few $ back? Ditch all 3l and just stick with 2l's?
Only reason I keep thinkn on 3l & 5l is the power lack. I find myself towing grossly overloaded loads 1ce or 2ce a year as it is with the 3l running an r150f box cos i killed the car duty g52 box so the 2.4 could be the straw that breaks my hiluxes back for towing ability. Failing those it'd be 1kz, 13bt...1uz....302w.... but then id be lookn seriosly at diff ladder bars ....sheesh... I think u get the picture.
Any help much appreciated - thanks
Tamati in Southland
tweake
Post by tweake »
CORROLUX wrote:I. Re the 2l 1 & 2l 2 motors Id like to know if there r any similarities or transferrable bits or setups between each other and or the 3l & 5l motors .
very little interchangeable with the 2l-1 and anything else (maybe the 1l).
between the 2lt-2, 2lte 3l, 5l most things are interchangeable.
CORROLUX
Post by CORROLUX »
Rats o well. I take it 2L 2 is in the 2L1 1 family too ?
tweake
Post by tweake »
CORROLUX wrote:Rats o well. I take it 2L 2 is in the 2L1 1 family too ?
no. 2l-1 and 2l-2 are different. the -1 or -2 is which version of the engine. version 2 is the later engine.
CORROLUX
Post by CORROLUX »
Ok...different enuf to share lots of bits with 2lt thru 5l's...?
Or even more different than ever?....
tweake
Post by tweake »
CORROLUX wrote:Ok...different enuf to share lots of bits with 2lt thru 5l's...?
a 2lt-1 is a 2l-1 with a turbo. neither have much in common with a 2l-2, 2lt-2, 2lte,3l or 5l.
CORROLUX
Post by CORROLUX »
Cool now we're getting places.
I realise 2l 2's the nxt 1 buuut....does that mean that 2l 2 shares bits with 3L & friends? Great info when bits hoarding. Saves buying bits that r no use having.
stealth
Post by stealth »
Having some issues with my 2.4, the pump was leaking so had a new seal installed but in error the little arm inside the pump got bent or broken, the garage has sourced a 2nd hand pump and put it on, but have had many issues in getting it to start and run as it did previously they think it could be injectors or bleeding the air out of the lines (or similar). Reading this tread has got me thinking about subtle differences that might occur like teeth count on the pulley, or marking on the pulley to line up timing etc, Is there any differences or any ideas from the 2.4 gurus in this thread?
TIA
