hey guys. Just wanting to replace the stock air box from my navara. The one it comes with is a cylinder type and wont take a k&n air filter so I want to replace it with a panel type that will take a k&n, I would like to know if this is possible and if it is what kind will fit, like if an air box from a differant kind of vehicle will fit in nicely.
Cheers Liam.
air box
Re: air box
Im not sure if your Navara is petrol or diesel or if it has a MAF sensor or map sensor but either way the air filter sits infront of any sensor so just about any kind of airbox and filter combination should work just fine.
The air box from a primera or pulsar should fit ok with minor modifications and they both take a panel filter.
Hope that help you out.
DS
DS
Patience is not a virtue. Its a weakness!!!
Re: air box
will it fit though? lol
Re: air box
I fitted a terrano filter in my navara pretty sure k@n do filters for them and they are a straight bolt in you just have to re plumb the air intake i left my fatory filter on there as had straight pipe to snorkle
mines a nonturbo if that makes any differance
could do pic if u want
Warren
Warren
Re: air box
rockyman wrote:will it fit though? lol
should do. Navara is basically identical to terrano from the cab forward etc.
but dont quote me
Addicted to Mud.
Re: air box
so maybe a terrano airbox then?
Re: air box
what motor has the navara got?
Re: air box
nz new navaras have td27 non turbo and imports td27 turbo i belive
find someone with terrano same model as yours and get them to pop the bonnet to have a look or try a car yard
Re: air box
TD25, TD27, QD32 atmo and turbo efi and mechanical versions, ZD30. also the v6 and 4cyl petrols.
Re: air box
got an airbox out of a primera. it fit in pretty nicely without much hassle. would recommend doing it, i got HEAPS of power increase
Re: air box
pics !
wheres the pics !
wheres the pics !
