Have rebuilt winch,at the stage of fitting to vehicle(had elect before)and trying to get as far back as possible so I don't end up with a park bench on front of my vehicle.going to keep same bull bar as before,well use std mounting type system for winch with a cut/tuck here and there to help keep cost down.
I don't have a body lift so cant lift winch up feck all(approx 20mm)
I have pushed winch back as far as I can and may try and tilt the front up little as some say this helps approach angle.need to check drive shaft angle while doing this I guess
middle of fairlead is approx 800mm off ground,not sure if thats good or not
# Any tips for pushing winch back
# Drive shaft has spline/slip joint on front section(mine is seized at this stage)is it ok to cut this shorter to make up for moving winch back?
PTO pics up tomorro.
This is what I have so far,rear most winch bracket is now sitting on top of chassis rail.I was going to reverse(make new one) the L shape plate the fair lead is on so it points under the winch instead of foward,by doing this I can cut just over 4" inchs off the front guides.
Elect winch set up vvv
Shane
