lpg in a 3y toyota
For all topics relating to Petrol engines and modificiations.
new2zukes
lpg in a 3y toyota
Post by new2zukes »
hi well ive got a 3y in my suzuki now and want to limit the carby problems by using lpg. does anyone know the cheapest way i can setup an lpg conversion? my truck will never see the road so no need to get a cert. hope someone can help me out here. thanks
martin
J_Dub
Re: lpg in a 3y toyota
Post by J_Dub »
http://www.trademe.co.nz/Browse/Listing ... =228178508
$250 and its yours, its out of my 3y, so its a perfect bolt on, away you go match.
i got an extra 100ks with the lpg compared to petrol, removed it only cause i dont drive it enough to justify having it, and was up behind my rear axle, and wanted it out of there.
Everythings there, works mint, took it out couple monthe ago in perfect working order
new2zukes
Post by new2zukes »
hey ye that sounds mint, is that round thing instead of the carby? if not how does it conect?
J_Dub
Post by J_Dub »
still goes through the carb
theres a diaphram that sits inside the air cleaner, i could give you my air cleaner and swap for yours, as mines got holes and everything suited to bolt up to 3y.
that round thing is the mixer thing that changes the l.p.g from a gas to a liquid... or vise versa... i think, not that clued up on the technical side of it..
basically, everythings there, it came out of my 3y, so piece of piss to fit back to yours. 1 hard line from tank to engine bay, couple a hoses to heater/ water lines, couple hoses to carb.. done
new2zukes
Post by new2zukes »
hey well that sounds like the go, i presume you can run purely lpg as i dont wana stuff around with petrol as well as lpg. im not sure when i am able to pick up but maybe next weekend as my parants are coming down to auckland.
J_Dub
Post by J_Dub »
yep that makes it easier as it is more ideal to tune it to the 1 fuel, rather than trying to tune it and get it to run good on both, be in touch then mate, i wont re-list after auction finishes
new2zukes
Post by new2zukes »
ok thanks for that, shows ore is a very helpfull sight:) well il give you a pm when im coming down, do you live in pukekohe? might have to come down myself as parents are going to be real busy in auckland cus me bro is going over seas and parents trying to get all his stuff out of his flat. cheers
martin
J_Dub
Post by J_Dub »
yep in Puke but could get as far as central Auckland if that helps mate
