rokhound
Post by rokhound »
hey Richard.
What is the purpose of the bung you are tapping in? If it is to only drain the water after the fact, it is too late, the damage has already been done to the bearings etc as the contaminated oil has already been through the system.
Bulletproof
Post by Bulletproof »
rokhound wrote:hey Richard.
I don't think a little bit of emulsified oil causes too much damage to the bearing on a trip while the diff is being used.
My problem is that the truck doesn't get used during the week and thats when the rollers go rusty, so as a safeguard I want to make sure no water is trapped there. Its not costing me anything as I have all the gear on hand. There could be water in this compartment without any getting into the rest of the diff if it comes in through the pinion seal because the water will sit at the bottom.
When you drain the diff this compartment doesn't get drained so I want to make provision to drain it. It retains fluid to a depth of nearly 35mm
Cheers Richard
Never say die, up man and try
chevrolux
Post by chevrolux »
hi,
not a question about your diff. but I was wondering if you knew where i could bet a bull bar the same style as yours? been looking around and they dont pop up any where! i really like the style and the ' :evil: ' factor.
timmay556
Post by timmay556 »
I found this one on TM for 95$. Just keep your eyes open and check TM from time to time.
Bulletproof
Alot of people contact me and try to make a copy but they dont seem to look quite right.
The steel is 78mm dia and 2.5mm thick
My one is a SMITTYBILT from Cal. USA
Here is the Name on it. They make alot of bars especially for jeep.
I would suggest you contact them through there website and see if they have an outlet in NZ. They might send one direct.
Cheers Richard
chevrolux
Post by chevrolux »
Thanks very much. Will check out that website :)
Smurf
Post by Smurf »
Bulletproof wrote:Alot of people contact me and try to make a copy but they dont seem to look quite right.
Cheers Richard
Mine came out looking ok? Well not bad for a nasty knock off homemade copy.
Bulletproof
Subaru hill with Andi in the Strange Rover in 2000
Cheers Richard
hosehustler
Post by hosehustler »
Wow has that spot changed since then :shock:
I hate signatures
Bulletproof
Today I went to toyota and priced a New Ring and pinion to go with my new locker and they told me $ 2500 so with the locker and bearings would total $ 5000 so couldn't justify it considering I have 3 used sets in the shed.
Think I will just carry a spare set on a trip.
Cheers Richard
H2OLOVA
Post by H2OLOVA »
guy on trade me selling genuine gear sets $900 for a pair :?
wjw
Post by wjw »
or $400-500 for aftermarket ones.
Who knew Prados could fly?
rokhound
Post by rokhound »
Which can be sent Via Bobby Longfield for some cyro treatment and then be stronger than original to the power of 10 :twisted:
Bulletproof
wjw wrote:or $400-500 for aftermarket ones.
Hi Bill
Are these the chinese ones?
I asked Jafa about his Trailgear ones but they are not available in 4.56 and Im not keen to try chinese as the ones I have seen in boxes don't impress me too much.
Has any one any feedback on them ?
Cheers Richard
rokhound
Post by rokhound »
IcedJohnno
Trailer Trash
Post by IcedJohnno »
You could also ring Craig at
South Island Bearing Distributors Ltd
cnr Kingsley & Brisbane Sts Sydenham Christchurch
Ph 03 377 3222
I know he stocks Italian made ones that hold up in rally cars (they often use Hilux diffs)
wjw
Post by wjw »
Having seen the difference between the chinese ones and the yukon and trail gear ones, I wouldn't touch the chinese ones. How quickly do you need one?
wjw
Post by wjw »
NZD $314 + shipping
http://www.ringpinion.com/ProductDetail ... rodID=1306
Shipping will be from $67 NZD
http://ircalc.usps.gov/IntlMailServices ... 5&O=0&sd=1
I'd need to know how quickly you wanted it and speak to my brother (whos in New York), the only way to avoid big shipping is to ship to a local US address and get it sent US Postal Service to New Zealand.
SMOKEY
Post by SMOKEY »
Hi Richard, you say you have some used sets, if they are not through the hardening or showing to much signs of wear they will be fine, set the diff up to minimum tolerances, if the crown wheel and pinion have running marks try and set them to achieve the original markings, a little less backlash and slightly tighter preload will be fine on a pre run set. The very worst it can do is winnnnneeeeee a bit and with your hearing and the stereo blasting out your 50's and 60's music,
YOU WILL NEVER HEAR IT.
FITZY.
Bulletproof
Decision made.
Bill (WJW) ordered me a Yukon Ring and pinion from the States last night .
Just have to wait now but not the end of world because the existing diff is still OK. Just hoping for a stronger setup all round.
I have never blown a diff but this is a worry when a piece of tooth falls out in the middle.
Cheers Richard
andrew007
Post by andrew007 »
hi richard,
how many years you been running that diff b4 this happened?
how much is the new set costing & was that the front or back?
cheers andy
Bulletproof
A photo I took of Willy from Blenhiem in 1996 that won the "NZ 4 Wheel drive" mag photo and a years free mags.
After the Suzuki Willy bought a Nissan Safari and he was so disappointed he gave up 4 wheel driving and now plays on a 4 wheel motor bike.
Cheers Richard
haynzy
Post by haynzy »
Bulletproof wrote:Decision made.
Cheers Richard
Your a builder richard, just mix up some bog and add some extra hardner to make it a bit harder and she'l be right, if that doesnt work pva some h3 msg8 timber in there. :lol:
BTW Im a builder too so dont take offence :oops:
Bulletproof
If you look the picture beside the pinion, that is what I am doing. Plenty of red hardner in the mix. :oops: :oops: :oops:
If I had a lathe I could turn up a hardwood one :idea: :idea:
Looking forward to meeting you guys in Oct on my North Is trip.
Cheers Richard
SMOKEY
Post by SMOKEY »
I don't think a chippy would be able to repair that, but the last time I chipped a tooth like that was when I was young and silly ( yeah I know ) and opened a Beer Bottle with my teeth, the Dentist made a brilliant job, $400 and 10000 bites latter still going strong.
NOW OLD AND SILLY,
FITZY.
Bulletproof
SMOKEY wrote:I don't think a chippy would be able to repair that, but the last time I chipped a tooth like that was when I was young and silly ( yeah I know ) and opened a Beer Bottle with my teeth, the Dentist made a brilliant job, $400 and 10000 bites latter still going strong.
NOW OLD AND SILLY,
FITZY.
Still chewing the idea over Fitzy. I was going to ask for the name of your dentist so I could have it capped.
Second thoughts. Your dentist at 20 wouldn't be alive now. :) :) :)
Keep smiling and remember to call in.
Richard
pre heat the whole thing , use a hard facing electrode, careful mill job and polish, :D sweet
Bulletproof
I put a post on today about the Tundra 8 inch diffs and how they have been strenghten up.
I already have the diff housing that is trussed
The tundra diffs have shims to adjust the side bearings but I think the principle of the gussets is a worth while modification to remove the flex from the crown wheel.
The tundra also has a bigger pinion but still has an 8 inch crown.
A person could make the gusset out of ordinary plate .
All that would be required is modifying the diff housing backward, so ground clearance
wouldn't be affected but the diff would be alot stronger.
Cheers Richard
Bulletproof
Update for our North Is trip
22 Oct crossing the ditch 1.15 sailing and most likely going to Palmerston.
23 head north on a private 4X4 trip over labour weekend
26 go to Te Aroha to stay with Wayne (Mudzilla) and do Thompsons etc mid week
30-31 head to Auckland and do the Extreme Park or Woodhill or something
Monday 2 Nov stay nite in Wellington
Tues 3 Cross ditch on 10.25 sailing
I will update nearer the time
Cheers Richard
Jafa
Post by Jafa »
We'll have a bed for ya in Palmy on the 22nd
021 273 9942
jafa@inspire.net.nz
